hard harsh vibration
Old Feb 10, 2001 | 01:16 PM
desperado_18_2000's Avatar
desperado_18_2000
ok guys.. i'm about tired of this truck my 82 f-150 351c is vibrating fiercly about 30mph.. the motor mounts are good and the tailmounts for the tranny are tight.. all the bellhousing bolts are in.. but it vibrates so hard its unbearable.. any suggestions??
Old Feb 10, 2001 | 01:20 PM
PAUL_2's Avatar
PAUL_2
Have you checked the driveshaft U Joints ?
Old Feb 10, 2001 | 01:47 PM
nwp's Avatar
nwp
Well, I had a clutch job done recently and when they balanced the flywheel, they took so much meat out of it the machinist couldn't believe it - it's the first one I've requested to be balanced-usually I just have em milled - but the vibration left after I pulled the clutch assy and ran it so I suspected the clutch or flywheel.... I'd had vibrations pretty bad for a while - and now - all gone!.... also, if it's not the u-joints, you might have a bent axle or bad axle bearing.... It'd have to be pretty bad to be unbearable, but those things are easiest to find.
Old Feb 10, 2001 | 02:59 PM
blownf350's Avatar
blownf350
FUNNY U MENTION THAT IT COULD BE THE REAR TIRES HAVE SHIFTED A BELT I KNOW IT SOUNDS FUNNY BUT ITS ACTUALLY HAPPENED
Old Feb 10, 2001 | 03:39 PM
blownf350's Avatar
blownf350
stlrfan1
1983 - 2012 Ranger & B-Series
Jun 20, 2013 08:07 PM
Pat Pittman Jr
Jul 9, 2012 06:22 PM
GMtoFord
Oct 14, 2005 01:08 PM
mowreyp
2004 - 2008 F150
Apr 17, 2005 04:02 AM
l.stull
Mar 16, 2005 02:27 PM
