Under hood vibration
Old Jul 6, 2012 | 01:04 AM
Pat Pittman Jr's Avatar
Pat Pittman Jr
I have a 79 with a 302 and it just started the bad vibration. It's hard to start and backfires sometimes. Can it be in the ignition or the crank.
Old Jul 6, 2012 | 05:13 AM
Ken Blythen's Avatar
Ken Blythen
If the vibration & the engine miss are related, then this won't be your problem.........but about a year ago I bought a 302 truck with a vibration at a high idle, that I thought was a harmonic balancer problem, as it had been swapped by the PO, & he wasn't sure he had the right one.
It turned out to be a worn-out fan clutch hub, that was allowing the fan to move around on/off center by about 1/8", so the vibration varied slightly, as it shifted.
Old Jul 9, 2012 | 06:22 PM
Pat Pittman Jr
Now I inspected the distributor and found the 3 wire plug coming from it was busted in pieces. Now I need to find out what wire goes where. The 3 wires from my distributor are different colored from the plug it goes to.
PinkFloydEffect
2004 - 2008 F150
Dec 19, 2015 10:16 AM
TestPoint
Mar 9, 2015 07:00 AM
901
24
Jun 15, 2008 04:55 PM
joe martin
2004 - 2008 F150
Apr 7, 2004 04:32 PM
