take off oil pan
Old Feb 9, 2001 | 10:55 PM
bb79ranch's Avatar
bb79ranch
take off oil pan
Old Feb 11, 2001 | 09:57 PM
murphydo's Avatar
murphydo
take off oil pan
i might take to the oil pan off and replace the gasket just for the hell of it, what is a good gasket to get and do i need to use anything like rtv blue to seal it. Thanks
Old Feb 12, 2001 | 12:34 AM
PAUL_2's Avatar
PAUL_2
take off oil pan
What engine is in your truck ? Is the oil pan gasket leaking ? If its not leaking why change it ?
Old Feb 12, 2001 | 07:46 AM
TallPaul's Avatar
TallPaul
take off oil pan
I wouldn't do it, but if you are determined to go in there, at least make sure to check the oil pickup screen is not clogging. My pickup screen was half clogged at 70,000 miles (mostly previous owner).
Old Feb 12, 2001 | 08:13 AM
slikness's Avatar
slikness
take off oil pan
Man, that's not a job that I would want to do just for the fun of it. But, if you must, get the one piece gasket with the steel inserts on the bolt holes. I just used enough RTV to hold the gasket in place on the engine block while I pushed the pan in place and bolted it down. Make sure you let the RTV dry a little and get good and tacky. Most gaskets come in 4 pieces but JEGs and Summit both sell the one piece.
'82 F150 2WD w/351W (orig 300 I6)
Slik
Old Feb 12, 2001 | 05:31 PM
otto's Avatar
otto
take off oil pan
Fel pro makes a real fine rubber 1 piece gasket with the steel inserts so you just tighten till it stops and thats it, it also comes with some neat little studs that will support your oil pan so you can put the bolts in without 4 arms, but like they said if it isnt laeking i wouldnt mess with it
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
