302 head ?s
Old Mar 31, 2005 | 02:08 PM
smoke n tires's Avatar
smoke n tires
302 head ?s
i have a 78 302 and i recently came across some 68 302 heads. other then the rockers and studs are they a bolt on deal or are the accessory bolt holes different? i want them for the compression. i believe it raises a flat top piston 302 to 10.5-11 to 1. mine has stock flat tops with the big chamber heads and its around 8.5 to 1. any info is appreciated........
Old Apr 1, 2005 | 10:18 AM
ronclark's Avatar
ronclark
When I put a 69 302 in my 85 truck to use as a test mule the accessary bolt holes were different. They were spaced closer together and the power steering AC bracket wouldn't bolt up.
Old Apr 2, 2005 | 11:41 PM
baddad457's Avatar
baddad457
I've never seen small block heads that had differently spaced accessory bolt holes. There were however different size threads though. Early heads had 3/8" holes, the later ones were 7/16"
Old Apr 4, 2005 | 12:00 PM
ronclark's Avatar
ronclark
I'm sitting here today with 5 stitches in my arm where I let a die grinder slip last week when trying to elongate the bolt holes in a power steering bracket from an 86 302 because it wouldn't bolt up to the 69 heads. The accessory bolt holes were about 1/8 in closer together on the 69 heads.
bfbronco
13
Feb 23, 2012 09:49 PM
TMI
Oct 15, 2008 08:29 PM
smoke n tires
Jan 18, 2005 08:48 PM
Kelly Champagne
Sep 24, 2003 05:04 PM
jc78
Apr 8, 2001 11:28 PM
