Bad AC Compressor Bypass
Old Aug 11, 2014 | 03:50 PM
jesuscowboy's Avatar
jesuscowboy
I have a compressor going bad. I don't want to end up stranded and I don't have funds for compressor and related parts. I have looked and seen post of the 7.3 a/c bypass but nothing for 6.0. Has anyone done this and if so what is part # and where did you get it from. If I have to do compressor can I replace and not hook up hoses and run till I can get the rest finished?
Old Aug 11, 2014 | 05:44 PM
Money-Pit's Avatar
Money-Pit
Is the compressor locking up and burning the belt, or is it just not cooling the truck? If it's just not working, and the belt is fine...run it til you have the funds to fix it...it won't hurt anything. Just don't turn the ac on.
Old Aug 11, 2014 | 06:28 PM
jesuscowboy
I suspect it is going bad I was yesterday and air quit blowing cold. I stopped for twenty minutes and truck would not crank. Acted like dead batteries but I just replaced. Trying to crank I smelled belt. I read that compressors lock up and will not allow cranking. I sat for about ten minutes and then it cranked.
Old Aug 11, 2014 | 06:33 PM
Money-Pit's Avatar
Money-Pit
Ohhhh, yea sounds like it's locking up. Not good. I don't know of any ac delete kits for the 6.0.
Old Aug 11, 2014 | 07:16 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
I found an old post on PSN, said Ford f5tz-8678-ac, Ford F5TE-19A216-FA or Dorman part 34180, make sure it's for an 8 rib belt.
Edit: that might be the 7.3L part. there was a guy on the .org that said a dealer parts counter found him an idler pulley that worked on a 6.0 though, just no PN given. You could call international also
Old Aug 11, 2014 | 09:10 PM
Yahiko's Avatar
Yahiko
You can also take the clutch plate off the compressor.
Also remove the wire to the field coil so that it does not
energize.
Sean
Old Aug 12, 2014 | 08:23 AM
BryanStein's Avatar
BryanStein
Just unplug the connector to the compressor clutch to keep anyone from turning it on and snapping the belts. I had a ranger with 320k miles on it that I ran for 20k miles with a locked up ac compressor. I just disconnected the clutch coil plug to make sure I never cut it on and snap the serpentine belt.
ManfredVonRichtofen
WTB - Parts & other
Jan 1, 2016 11:45 PM
wheelie31
Jun 20, 2010 10:36 PM
octaneforce
Mar 22, 2009 01:49 PM
HeywoodJ
Dec 7, 2008 07:26 PM
Wilber15
Nov 28, 2001 06:07 AM
