I'm using a forced hot air wood furnace bought used for $300 and $300 for a stainless through the wall chimney makes it very warm in a 24x30 uninsulated garage even during the long cold Maine winters........will be insulating, sheetrocking, and putting in ceiling in the next few weeks which will make it easier to heat too
Thanks, I have a guy from the gas company getting me some info on Renzor, Hot Dawg and a couple more. He reccomended a sealed combustion chamber and vented since I have a woodworking shop on the second floor. It's Buck Season here so things other than hunting don't get done too fast. I'll post what i go with and let everyone know how it works over winter.
Thermostat control consist of a small temp probe that is attached to the rear of the units via a approximately 6' wire. Both units usually start out low, get warmed up and will then kick it up to the desired level to warm up to 2-degrees above then will kick back down to low for a few minutes, shut off the burner, then run the fan for a few minutes until the burner is cooled down. The monitor has an economy mode were it will allow the room to cool down to 12-degrees below preset. It will then fire up and warm the room to 4-degrees above and continue that process. I have had both stoves over the past 15 years and do like the Monitor brand over the Toyo brand. They both are pretty fuel efficient. I had the large Monitor 45,000 model in my living room while I was building my house. Kept it comfortable during the winter. As for oversizing I would get the 25,000 btu model if I was only heating a few rooms or a small garage. Anything larger go bigger. They also make a one room heater that is actually a pretty nice unit just for that application.
I do like the in-floor heating. The only draw back is the additional cost. Actually its not to bad. Been considering placing heating tubes in the floor of my house and getting rid of the baseboards. I already have a boiler and circ pump so it would be a matter of new PEX. Slab is already in the garage so I cannot go that route.
As for Electric heat. At $0.23 a kilowatt forget it. Just not economical up here. Pelet stoves are nice but the shipping for the pellets to get them up here also make it expensive.
I'll try to take a look at the TURK burner to get an idea on what it would take.
Right now I have been running a barrell stove and only heating it when I need to. Takes an hour or so to get it at a comfortable temp to work. Been the cheapest route for now. Still would like to have full time heat but that will probley have to wait till next summer.
Found 3 pics of my turk burner when I first built it. Posted them to my gallery. The next time I clean it out I will take more pics of the different parts and will post them. It uses about 3/4 gal waste oil/hr, and put's out a Huge amount of heat........FOR FREE!!! FABMANDELUX.
Reason: Boo-Boo
Thanks. I will take a look when I get back home this coming weekend. Attending training and have a REAL SLOW laptop from work with a REAL SLOW internet hookup.
Temp outside is in the teens and I can work on stuff in a sweat shirt and coat with bare hands and If I get cold I just go stand by the Boiler till I warm back up. Plus this heats the house via Hot water.
I am working on making a room for the furnance should have that in place by Jan.
The doors in the garage don't seal tight at the bottom at all so If I have any gas vapors they disperse out the garage doors. Plus all flamables are stored in outside garden shed and the garage is not attached to the house.
also Have a 4" vent hole in the wall behind the stove pipe for the Damper effect to keep smoke going up the chimmeny.
This is my set up. More or less, I now have a fixed bracket system for the holding tank on top the furnace the set up there was temporay to make sure it didnt' leak first.
WEll I can't afford any of those fancy type heaters. My old Triumph Wood stove sitting in a corner, and 1 lazy ceiling fan keep my garage warm..... But I do have to plan my shop time in advance and light the logs when needed.
