Sponsored by: Auxito
new motor
Old Mar 30, 2005 | 07:51 PM
schwingdoc04's Avatar
schwingdoc04
Question new motor
Looking for any info. Have a 97/98 f150 supercrew longbed 4.6 triton xlt. about 160k. Want to redo motor and tranny to deal w/ hauling concrete pump and trailers. love this truck, please do not recommend a 250 or 350. What is the best heavy duty motor and trans I can swap out with this body ??? Any help is appreciated./
Old Mar 30, 2005 | 11:00 PM
LxMan1's Avatar
LxMan1
The 5.4 is a good engine. Long stroke. Mine tows 7,000lbs pretty good. The 4R70W is a good tranny, with a good cooler on it, it should work fine. You would need a donor truck so that you would have the correct wiring harness, computer, exhaust Y-pipe etc. The 5.4L block is taller and wider than the 4.6L. Also, if you get a 99 or newer, it will have the PI heads and have more power 260hp and 350lb/ft of torque. Also, lower gears like 3.73 or 4.10 will help alot too.
Old Mar 31, 2005 | 10:09 AM
B_7700_4X4's Avatar
B_7700_4X4
I second the 5.4, but if you can get a 4R100 trans, it would be more suited to your application I think. The gear swap is also a really good idea.
Hogin
Engine Swaps
Sep 19, 2014 03:08 PM
norm666420
Jun 11, 2014 07:42 PM
jimmyredmond45
1997 - 2003 F150
Nov 25, 2011 02:16 AM
DesertStorm
4 Cylinder Engines
Dec 21, 2007 08:49 PM
1950t
Dec 26, 2005 06:02 PM
