blower motor problem!!!!!!
Old Jun 11, 2014 | 06:30 PM
norm666420's Avatar
norm666420
Blower motor stops when I go over 65 mph , any idea why?
Old Jun 11, 2014 | 06:37 PM
eakermeld's Avatar
eakermeld
Check and see if it is still coming out of the defrost vents.
Old Jun 11, 2014 | 06:45 PM
norm666420's Avatar
norm666420
It doesn't , it completely quits blowing then when I slow down to 60 it will start up again almost if something gets blocked then unblocked when I slow down
Old Jun 11, 2014 | 06:48 PM
SteelHorse4x4's Avatar
SteelHorse4x4
Its the FLUX CAPACITOR. For god's sake, whatever you do, don't hit 88 mph. Sorry, had to do it.
Old Jun 11, 2014 | 06:49 PM
norm666420's Avatar
norm666420
Lmao!!!!!!
Old Jun 11, 2014 | 06:52 PM
eakermeld's Avatar
eakermeld
Probably what's happening is you have a vacuum leak. When you are on the throttle vacuum drops and the air doors can't keep their position so the block off the air going into the cab. Most of the time it diverts it to the defroster as an emergency measure. Look under the hood by the top of the blower motor. There will be a whitish colored hose going to a valve on the heater hose. That is the most likely rotted and broken. But a leak from anywhere could cause this.
Old Jun 11, 2014 | 06:53 PM
eakermeld's Avatar
eakermeld
Oh yea, UNPLUG the Flux capacitor first!
Old Jun 11, 2014 | 07:07 PM
norm666420's Avatar
norm666420
I will give it a look thanks for the advice!!!!!
Old Jun 11, 2014 | 07:39 PM
SteelHorse4x4
second on the vacuum line. They are plastic, and occasionally break. Should be white, and can break right where they go into the loom.
Old Jun 11, 2014 | 07:42 PM
norm666420's Avatar
norm666420
Thanks I will give it a look when I get home next week.
mikeinri
13
Jul 5, 2015 10:44 AM
brandonellisce
2009 - 2014 F150
Jun 20, 2015 11:46 PM
brandonellisce
2009 - 2014 F150
Jun 19, 2015 05:58 PM
Tormz
Dec 4, 2013 09:48 PM
boggerted
Jul 18, 2007 02:15 PM
