clatter at startup
Old Feb 15, 2001 | 09:34 PM
brown 4x4's Avatar
brown 4x4
clatter at startup
Lately I've noticed a clattering for the first few seconds when starting my truck in the mornings. I've heard the type of oil filter can cause this. I have been using filters from Carquest and 10-W30 oil. Anyone else use these filters and have this problem, or do I have something else wrong?
1986 F-150 4x4 300 I6 NP435
Old Feb 15, 2001 | 10:18 PM
tye's Avatar
tye
clatter at startup
Make sure you are using filters with the anti-drainback valve in them.
1991 F250 4x2
300 I6 5speed
Old Feb 15, 2001 | 10:29 PM
fatforty's Avatar
fatforty
clatter at startup
Hi, I go to advance auto and buy motorcraft filters for the same price as all the others and they have anti drain valves in them. The best thing to do is change the filter and see if the noise goes away if not then you have other problems.
John
Old Feb 16, 2001 | 04:35 AM
laka's Avatar
laka
clatter at startup
You might have sticky lifters. Try some engine flush and an oil change.
Old Feb 16, 2001 | 06:05 AM
carlos57's Avatar
carlos57
clatter at startup
Have you recently changed brand of oil. When I use a Pennsylvania crude like Quaker State or Penzoil I get a clatter. If I use Castrol or Havoline I do not. Used to use Fords oil but they changed the formulation and I now get clatter.
My current truck has a 300 I6 and once a couple of years ago the quicke lube place didn't put Castrol in. I was back next day and they changed it for free because they screwed up and used Penzoil.
It's not like I change oils every other change, this is many vehicles over a lot of years. I currently use Castrol 10w30 in my Fords.
Carlos
Old Feb 16, 2001 | 12:38 PM
Franklin2's Avatar
Franklin2
clatter at startup
Check this site http://members.nbci.com/minimopar/oilfilterstudy.html
Old Feb 16, 2001 | 05:05 PM
brown 4x4's Avatar
brown 4x4
clatter at startup
My engine only has 12,000 miles on it, so I would hope that it's not the lifters. I think I'll try a different brand of filter and see if it helps.
Old Feb 16, 2001 | 07:30 PM
biglurp's Avatar
biglurp
clatter at startup
I'd say it's the anti-siphon on the filter. I've been real happy with purolators pure-one filter. It's a little pricey but I think it's worth it. Also I have heard nothing but bad things about fram's...Gary
Old Feb 17, 2001 | 11:08 AM
Phillip Guidry's Avatar
Phillip Guidry
clatter at startup
I have a 300 also, and, will vouch that WIX # 51515 is the best filter for the 300. I too had a rattle at start up after a long sit, and noticed that the oil gauge seemed to not respond as quick as I liked.The rattle naturally would go away as soon as the oil gauge responded, so I knew that oil filter was taking a long time to fill up. I started trying different filters week by week until finally, I caught my senses and purchased the WIX.....problem solved !....big time ! All the other filters stated that they had anti-drainback valves, but the only brand that does the job on the 300 because of its horizontal position on the side of the block, was the WIX. Try it out.
Phillip
Old Feb 17, 2001 | 03:30 PM
billyb's Avatar
billyb
clatter at startup
