have codes 4.9l need help....
Old Mar 29, 2005 | 10:13 PM
dogpile's Avatar
dogpile
Question have codes 4.9l need help....
411..secondary air induction, incorrect flow detected.
1151...o2 sensor..lean
Old Mar 30, 2005 | 12:23 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Mar 30, 2005 | 04:33 PM
bigredsbronco's Avatar
bigredsbronco
what year of vehicle is it
Old Mar 30, 2005 | 09:52 PM
dogpile's Avatar
dogpile
Its a 96... I have been told that the 411 code could be from the 02 sensors.
If this is true, is there a way to determine which of the three is causing this?
Any advice would be appreciated. The problem with the truck, is that it misses under a load, have replaced the fuel pump, coil, plugs, wires...
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
