Crankshaft Endplay?
Old Mar 29, 2005 | 08:31 PM
fordmudrunner2020's Avatar
fordmudrunner2020
Crankshaft Endplay?
What is the crankshaft endplay supposed to be on a 1989 7.3L. Thanks
Old Mar 29, 2005 | 08:38 PM
Scott Fraser's Avatar
Scott Fraser
Crankshaft Endplay 0.0025- 0.0085 in. Service limit .012 in.
Old Mar 31, 2005 | 07:20 PM
fordmudrunner2020
Thanks Buddy my endplay checks out so now I can move on to try and figuring what else could cause my clutch problems.
Old Mar 31, 2005 | 08:01 PM
Scott Fraser
What kind of problems are you having with your clutch?
Old Mar 31, 2005 | 08:20 PM
fordmudrunner2020
It is not disengaging and it still grabs fine. The Slave cylinder moves the proper amount and the clutch fork is not bent. The pressure plate still has the machining marks in it and the clutch looks like new. What I did find though was that the machined piece that bolts to the fly wheel moves a little and the bolts are tight so I'm thinking thats the problem so I'm going to go and pull the flywheel tonight.
texasyeti
May 6, 2010 04:28 PM
plgebbia
Mar 15, 2010 10:53 PM
cujo8
20
Apr 26, 2006 09:17 PM
Fordknut
Bronco II
May 28, 2005 09:47 PM
pcullins
Oct 21, 2004 07:33 AM
