Bronco II Ford Bronco II
2.9 Crankshaft Endplay
Old May 24, 2005 | 05:43 PM
Fordknut's Avatar
Fordknut
A friend of mine has an '89 B-II with a 2.9 and auto trans that has excessive crankshaft endplay. So bad, in fact, that the flywheel now interferes with the starter. I have an '89 B-II w/Auto "parts vehicle" and I thought we could use the engine out of it. Guess what, this engine also has excessive crankshaft endplay; about 3/16". I checked the endplay on my '86 Ranger w/5 speed as well as an '88 Ranger w/5speed and both have negligible endplay in their cranks. I have always been led to believe that engines with std. trans. were most prone to endplay wear due to the thrust applied through the clutch action. Is excessive crankshaft endplay a common problem with these engines? I don't recall any discussion about it in the past. Any comments from others with experience with this problem will be appreciated. Thanks, Brian G. NY
Old May 28, 2005 | 09:47 PM
Help I M Stuck's Avatar
Help I M Stuck
time for new crankshaft bearings??
DIYMechanic
1241
Jul 14, 2018 07:28 PM
jthuston
Feb 22, 2015 07:23 PM
1950FordF1
Nov 26, 2014 06:06 PM
frdnut
1997 - 2003 F150
Mar 30, 2014 07:37 PM
Robert Vandervennet
Oct 28, 2012 03:55 PM
