Rad Support mount
Old Apr 1, 2005 | 10:11 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Radiator part #'s
Originally Posted by GreatNorthWoods
Bobby,
What year is your truck and where does the Cad engine require the radiator outlets? I will be needing one that requires the outlets on the center or left side on the top and on the right side on the bottom. If that is what yours has can you give me a part number or exact application?
Vern
GreatNorthWoods,
hey man, I found the part # for the radiator that I installed im my truck. I had to make my own radiator/fender support bracket because the lower bends on the original had to large of a radius. I will take some pictures over the weekend and post them on Monday.
Here is the specs on the radiator as read from the tag on the box;
Ready-Rad
Heatbuster
Replacement radiator
#43-6006
Chrysler
Replaces Industry Model #1586
Go/Dan Industries
UPC# 0---40876-46006---5
Hope that sheds som elight on things for you
Bobbyt
Old Apr 4, 2005 | 06:43 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Bobby,
Thanks for the info. I'm going to look into this radiator for my 48 F-3. I kew from previous posts that a Dodge truck radiator from the mid 70s might work, but I never could get the exact model or part number. I appreciate it.
Vern
Old Apr 4, 2005 | 08:11 AM
bobbytnm's Avatar
bobbytnm
I was having trouble with my home computer, so if the info didn't get through---here it is again.
Ready Rad
Heatbuster
Replacement Radiator
43-6006
Chrysler
Replaces Industry Model 1586
Go/Dan Industries
UPC# 0--40876-46006--5
Bobby
Old Apr 4, 2005 | 08:33 AM
GreatNorthWoods
Bobby,
Got it! There's a 436006 on Ebay right now. It's a new 3 row radiator for a 75 D-200 for a buy-it-now price of $169 + $15 shipping. I'll look into local availability before I buy one on Ebay but it looks like a radiator I could easily install in my 48 F-3. I will be using the original core support, but it looks like the dimensions are close enough to the original to install it with little fabrication...plus the outlets are on the proper side and the right size for my particular engine.
Vern
Old Apr 4, 2005 | 09:36 AM
bobbytnm's Avatar
bobbytnm
Vern,
That's the one. I bought mine through a local parts house for $125. I can't remember if it was Autozone, Checker Auto, or Pep Boys. They didn't show the part number in their local store directory but I had checked their website first and knew they could get it. I had them order it in at no extra cost.
Good luck with it
Bobby
Old Apr 8, 2005 | 07:56 AM
GreatNorthWoods
Bobby,
Thanks to your information I bought the 436006 radiator on Ebay for my 48 F-3. What is the displacement of your engine and how well does this three row radiator cool it? Do you run a mechanical or electric fan and what degree thermostat are you running? I noticed that this radiator comes with a sensor fitting on the top tank. Do you know what that was used for in the original application? According to the seller this radiator fits a lot of applications in addition to the 72-79 Dodge pickup including Dodge Charger, Coronet, and Challenger, Plymouth Road Runner, Barracuda, Satellite, and Sebrings of the early 70s and even many Dodge vans up to 79 with 318 to 360 engines. It is a very versatile radiator and would be easy to find a replacement if I needed it. Thanks again for the tip...
Vern
Old Apr 8, 2005 | 01:31 PM
51dueller's Avatar
51dueller
I wonder if the sensor is for low coolant? Our 79 MF tractor has that.
Old Apr 8, 2005 | 02:47 PM
GreatNorthWoods
Nathan,
Could be, or it could be for temperature or some kind of emissions system. I don't have a clue. I can always plug it, but was just curious.
Vern
Old Apr 10, 2005 | 08:11 AM
GreatNorthWoods
Nathan,
I found out that's exactly what the sensor opening is for...low coolant. I wouldn't mind having such a sensor if I could figure out how it works and how to wire it in....might be cool.
Vern
Old Apr 10, 2005 | 03:53 PM
51dueller's Avatar
51dueller
It's just probally just a two pole sender and acts like a brake switch. When coolant is low it would send power to a dummy light on the dash.
Old Apr 11, 2005 | 09:55 AM
bobbytnm's Avatar
bobbytnm
radiator
Gentlemen,
I'm glad my tip for the radiator was useful. I spent quite a bit of time studying radiator websites trying to find a radiator from an existing application.
I'm running a 500ci Cadillac with an automatic trans. I'm using the original flex fan fan clutch and stock thermostat. I do know that the big Caddy engine tends to run on the hot side (215 -220 is normal). I may end up using an electric fan, I don't know yet as my truck isn't at the driving stage yet. I've barely got it up and running enough to check out all of the systems. In fact I just pulled the engine back out over the weekend so that I can box the frame and clean and paint everything.
On my upper tank there are only two openings, one for the upper hose and a 3/8"npt fitting that I used for the heater hose.
Most of the newer cars are equipped with low coolant sensors, so it should be easy enough to adapt one.
Bobby
Old Apr 11, 2005 | 10:17 AM
GreatNorthWoods
Bobby,
If this radiator will cool 500 cubic inches then I should have no problem. I will also be using a clutch fan if I have room for it and a non-clutch mechanical fan if not. I would use an electric fan only as a last resort or for part time cooling in extreme circumstances. I will try a 180 thermostat initially. I don't think 215-220 is unreasonable as long the temperature remains constant, but you don't have a lot of wiggle room.
Vern
Old Apr 11, 2005 | 10:39 AM
  #28
bobbytnm's Avatar
bobbytnm
Vern,
Like I said, I haven't actually had it on the road yet. The Caddy's ran hot from the factory. It get's pretty warm out here in New Mexico and I remember from my time as a Caddy mechanic that 220 was pretty normal operating temp for the early 70's cars. The 500ci Caddy has a stock 7 (maybe 8?) blade flex fan and fan clutch. I'm hoping that will be enough. I won't be running AC for awhile. I would eventually like to add it but that will be in the future. Right now I just want to get the truck where I can drive it. I think that as long as I can direct all the airflow through the radiator I'll probably be ok
My dad has a 75 Dodge D200 truck with a 440ci, automatic that he uses as a work truck and hauls a large trailer with. It has the 436006 radiator in it and handles the heat pretty good.
I'm hoping to have mine back together and running in a month or two. All it takes is money and time..............
Bobby
Old Apr 19, 2005 | 08:07 AM
  #29
GreatNorthWoods
Originally Posted by mtflat
It doesn't change anything on the fenders. The inner fenders should also have a second set of holes. Only thing that would be off is the air deflector that bolts to the hood - you'll want to move it so all the air goes thru the radiator rather than over the top. It's been a few years since I put mine back together, but I think there are slotted holes that should allow the air dam to move to either position.......... Barry can give you the numbers if I'm wrong.
I discovered yesterday that there's one other thing that is affected by moving the radiator forward to the holes used for a six cylinder. There is a metal panel at bumper level (don't know the technical part name for it) that goes in front of the radiator and directs air up into it. This piece bolts to the gravel pan/inner fenders and has a rubber edge on it that goes up against the original radiator to force incoming air into the radiator. My guess is that this panel was made differently for six cylinders than for eights because if you move the radiator 3 inches forward to the six cylinder holes this panel becomes three inches too wide to bolt back in. It seems to be an important piece because without it air coming in through the grille would just go under the truck instead of through the radiator. I removed the leading rubber edge, cut about three inches off the front edge of the panel and re-drilled two of the mounting holes in the inner fender which were removed when it was cut. Thought I'd pass this on to those who might be moving their radiator forward for extra engine room. With my new Dodge truck radiator I will have plenty of room for a mechanical clutch fan and will not have to use an electric fan.
Vern
Old Apr 19, 2005 | 08:49 AM
  #30
bobbytnm's Avatar
bobbytnm
Vern,
Great tip. I know the piece you are talking about but I hadn't considered it yet. I had the front clip on when I designed my new radiator mount but I figured I would deal withthat deflector later on.
Do you have any pics of it after the modification? Would be nice to see.
Let us know how the radiator works for you. I will be using a Cadillac factory flex fan as well as a cltuch fan and I don't think I'll need the elecric fan either.
Thanks again
Bobby
