OBD II Codes
Old Mar 29, 2005 | 04:10 PM
jimmyspencer's Avatar
jimmyspencer
OBD II Codes
Anybody know what P0113 means for a 1997 Ford Explorer sport?
According to the Generic Codes, it means "Intake Air Temperature Circuit High Input".
Any input would be appreciated.
Old Mar 29, 2005 | 04:57 PM
black wolf's Avatar
black wolf
Yup thats the one jimmyspencer.just under your brake pedal there is a cover like a fuse box and you can plug in your scanner to it and get your reading from there. i dont know what the cost is for the scanner but have ford extract it for you if you dont have one. i hope this helps
Old Mar 29, 2005 | 08:57 PM
Dialtone's Avatar
Dialtone
Not too sure about 97 but my 91 has a sensor screwed into the upper intake just behind the throttle plate. It is called Air Charge Temp sensor. As its name implies, it measures incomming air charge temp and is used in the fuel to air ratio calculations...Should be around a $25 part.
Dialtone
Sledhead3
20
Sep 20, 2016 01:09 PM
cookingguy
Nov 19, 2014 06:12 PM
1972RedNeck
May 30, 2012 11:33 PM
m50
Feb 11, 2011 05:45 PM
Lazy Gus
Apr 15, 2010 10:41 AM
