Led Lights
Old May 23, 2005 | 03:23 PM
SewerJack's Avatar
SewerJack
I already had the led blubs in and they worked great, also put them in my dodge dart with no problem, But someone stole my lense's off my truck and took the blubs out. If I can buy a set of these lights it will solve two problems for me.
Old May 23, 2005 | 06:04 PM
1970Custom's Avatar
1970Custom
I don't think the 73'-79' lens' will work in the 67'-72' housings, they're longer by about an inch and wider by a half an inch.
Tried it once with the factory lenses, because mine were cracked, and had no luck.
Old May 24, 2005 | 11:23 AM
jdbanks's Avatar
jdbanks
How similiar are the 67-72 Chevy/GMC tail-lights to the 67-72 Ford tail-lights? But if they're close in size and use the same type bulb, maybe this would work. http://www.earlyclassic.com/catalog.aspx
Of course you could modify it to work, might require rewiring for your bulb plug and trimming or something of the sort. They also have these for the 60-66 Chevy/GMCs.
-J.Banks-
Old May 26, 2005 | 10:31 AM
pcwb's Avatar
pcwb
I would also like to know what success you guys are having with this replacement. I bought the LED replacement bulbs to put them in my 69 and 70 trucks, they would only work when I turned on the emergency flasher, I think "beemer nut" is correct. I gave up on this, but now I may go back and research it, unless you have success.
Keep us posted on the results, please.
Old May 26, 2005 | 06:27 PM
SewerJack's Avatar
SewerJack
I had a set I bought from Autozone. I replaced the turn/brake lights and the backup lights. They were working great. If you couldn't see them you had to be blind, They were much brighter than the stock blubs. I did replace the pig-tails when I Changed the blubs out. for I would have a better connection.
1993 F250
Aug 24, 2011 04:59 PM
glenerd51
2004 - 2008 F150
May 18, 2009 09:23 PM
jaye
13
Feb 16, 2009 04:03 PM
Supercab
Aug 17, 2006 06:00 AM
01expyEB
Aftermarket Products
Mar 9, 2004 01:30 AM
