I have found a set of LED lights for as 73 and up trucks. I was wondering is their anywhere that sells the lights for a 67-72 truck. I would like to put them in my 69 F-100? Thanks for any help
no no no i am sorry i need to be a little bit more clear. These are not just the bulbs. These are the entire lens. The cover and everything. sorry about that guys.
Shackelford, I was wanting to know if you purchased a set of the taillights.
If you did I was wondering if you know the part number. I went to a Tractor Supply near the house looking and the guy told if I knew the stock or part number he could order a set.
I wouldn't say it is CUSTOM rather, it is a safety upgrade. the big trucks are all going to LED tail lights on trailers, and tail panels, so why would you wanna cut your 73-79 bedside for use of such a safety feature? I know there are ALOT of that year seiries trucks around still being used for heavy work. not to mention alot of your box bed manufacturers put these 73-79 lights in their tail panels, as they have backup lights already installed, and you only need to cut a rectangular hole to mount them.
I am sure if you wanted to get nasty about it, one could just swap out lenses to make it fit the 67-72 bed.
Don't forget these older vehicles have thermo blinkers as more the current the faster they blink. One lamp out and the blinker stops. Newer vehicles went to a electronic timmer that controls a relay, this system will work with LED's. This is with 1157's or 2057's brake / tail lamps. LED's run on alot less current like 20-30 ma's per LED. You must add a resistor to ground to load up the thermo blinker to blink, this should be in some of the LED conversion kits, be sure to ask.
Carl....=o&o>....
ranger, what he's talking about you dont have to cut anything , they fit right in the factory assembly. you put your factory lenses on after you install them.
