'05 F350 SuperDuty - Make the beeping stop!! Can't find the chime.
& this newer truck doesn't seem to have the solution i have read for
the older vehicles. Does anybody know either where the chime is or
where the wire is?
it is working as advertised.
i do not want any chime when i have the door open with the key in.
i disassembled half the dash trying to find it. it's like a cricket, it echoes.
my last truck '96 f350 was easy, i killed it in minutes. this one appears to
be behind or a part of the instrument cluster. it's nice that ford gives the
"simple" 9 step routine to disable the seat belt chime, but what about this?
is there a wire to cut, or is it the taping of the contacts in the key tumbler?
or, hopefully, is there a physical chime i can grab, and throw really, really far?
thanks, that's where i thought i was hearing it from.
i had half the dashboard apart.
any suggestions in removing the instrument cluster?
i just got this truck 3 days ago, and it's a lot different from
my '96
