Ignition Timing Advance Problem
Old Mar 28, 2005 | 07:58 AM
highgearonly's Avatar
highgearonly
Has anyone seen this?
1993 F-150 4.9 six, 5 speed manual
I set base timing with spout disconnected at 12 degrees BTDC.
With spout reconnected, checked advance by reving motor & watched timing jump to approx 20 degrees ATDC for a second and then go back to 15 BTDC.
Looks like advance is not working, I am hoping it is not the Computer.
Any other thoughts?
Thanks
Old Mar 28, 2005 | 08:09 AM
M.Stephens's Avatar
M.Stephens
If you have a computer problem, your check engine light would be on or it would be generating some codes.
If its running good, I wouldn't worry about it. But for discussion, I didn't think our ignitions actually advanced (not saying you stated it like that either). There's no vacuum lines or mechanical devices that advance the ignition like it used in years past. Its a computer thing, that involves alot more than RPMS alone. Anyone have a better understanding?
Old Mar 28, 2005 | 08:13 AM
highgearonly
You are correct, computer controls advance, but shouldn't you still be able to see advance change with rpm at the crank with the timing light?
Old Mar 28, 2005 | 01:57 PM
noFordguy's Avatar
noFordguy
i have a similar problem. noones replyed though. i set my timming to 12 DBTDC plug my spout in and its still at 12 DBTDC. engine light comes on evey so often not every time truck is driven. code is 213. not detecting spout. i put a computer in, modual, tune up, checked wiring, you name it. i also have acess to alldata for the diagrams. still the same problem. so i just set the base at 22DBTDC for now, runs great no spark knock.??????? im goint to pay close atention to this tread. thank you and good luck
Old Mar 28, 2005 | 03:35 PM
Silver Streak's Avatar
Silver Streak
Are you sure the rubber that holds the balancer together isn't flexing on acceleration? 20 degrees is a long way for it to flex, but might be possible.
I tried some different timing settings on the dyno last weekend. At 14 degrees power was good, but at 18 it was killing it on the top end by about 15 hp.
Old Mar 28, 2005 | 03:46 PM
highgearonly
I have not checked the balancer, do you think there could be that much flex in it? I have to check for codes as well.
Thanks
Old Mar 29, 2005 | 11:42 AM
Fords4Me's Avatar
Fords4Me
noFord- I've got the same problem "no spout detected".
My milage sux. You are @ 22 deg. BTDC? Does that work? I'll try it.
Old Mar 29, 2005 | 12:50 PM
noFordguy's Avatar
noFordguy
it worked for me. mileage is ok.195-230 miles per tank. of course depending on how much my foot is into it.
boought the truck with problem. how much mileage are these engines suposed to get.
3:08 gear(s) mazda 5 speed. 4x4, K&N,
i think it is a 15 gal tank. its in the rear.
Old Mar 29, 2005 | 12:58 PM
highgearonly
I get about 240-250 miles to a full back tank (front tank started leaking about 4 years ago so I don't use it) when the truck is running good.
Mine's also Mazda 5 speed OD, K&N filter pod, but with a 2:73 rear. I bought this truck new in Nov of '92 & don't plan on getting rid of it!
I also had timing adavnced to about 18-20 BTDC but it pinged pretty bad.
topfile
Aug 12, 2012 10:33 PM
cmdragon
1978 - 1996 Big Bronco
Dec 31, 2008 08:32 PM
Drac
Feb 1, 2008 10:19 AM
moondogg
Dec 22, 2004 11:13 AM
Boldt
19
Jan 8, 2003 11:51 AM
