94 f-150 5.0 when i set my timing with the spout out at 10-12 btdc.
then i put spout back in the truck wont idle. the only way is i have to advance
the timing to 16-20 and leave the spout out.
does this mean that pcm is bad also got no codes. except open spout duh
thanks moondogg
no im not i turned off the engine to remove or install the jumper. and the chain and gear set have been replaced and so have the heads has also ported and polished.
thanks moondogg
