Welcome to ( THE ) best ford truck site in the world! (FTE)
Look
On your warranty tag it is rivited to the drivers door, and then you could do a
search on rearends there are some very good info here. Does the rearend have
a bolt on cover, or does the gears load from the front of the housing ( 9INCH)
p.s some one else may ring in with the info!
You should be able to find a rear end assy with better gearing for your truck. Just have to watch for the spline count. They're either 28 or 31 splines.
