ping ping aling ping
Old Feb 27, 2001 | 11:25 AM
jams3's Avatar
jams3
hi all
well i am stumped only had the truck for 6 months
still learning about the computer controled fuel injected
stuff and what u can work on and what u have to take to
the shop.
need to have ready for the summer so i can tow my speed boat
(easer to work on then the truck)
so i am taking care of things as i can working on a buget
well its pinging.
this is what i have done
plugs gaped at 54
bosh wires
cap
rotor
timing set at 10 BTDC yes i pulled the plug to disable the advence
injector service but i was on happy with the job nothing
was hooked up to the fuel rail used a iv bag hooked it up
to the power brake vac line and put a bottle of cleaner
in the fuel tank.
it pings real bad on a hill close to the house but only
when it gets to 2800 rps or higher if i hit the od butten
it stops.
but of corse i cant pull the hill.
this 1 is ticking me off
dont now ware to go next
fuel presser?
injectors?
cencers? (have on codes) is there a nox cencer?
the temp on the truck at the time was running cool but that is gona be next stat and coolent.
i am running reg gas and the truck isent pinging on flat ground
or on lesser inclines.
94 f150 xlt teal in color 97000 miles 5.0/302 mass air
love this truck.
thanks for all the help
marc
Old Feb 27, 2001 | 12:48 PM
PAUL_2's Avatar
PAUL_2
Since its a Mass Air setup , check the MAF Wires for any debris that may be built up on them . If you do find they have dirt etc built up on them use some electronic parts spray cleaner to clean them .
Old Feb 27, 2001 | 08:04 PM
fatforty's Avatar
fatforty
Try cleaning the fuel injection not just with an add a can but take the throttle plates out and clean them really good clean everything you can use a small brush and spray can of carb cleaner should make a difference it works on the mustangs and they are prone to pinging. John
Old Feb 28, 2001 | 01:37 AM
jams3's Avatar
jams3
thanks paul and 40
i will clean the contacts on the MAF what about the cencer it self?
ware are the plates at i asume that thery are at the intake
and is it a pain in the b&^ ?
i all so found a place that has a motor vac
when i have the mulla.
thanks
regards
marc
Old Feb 28, 2001 | 11:58 AM
PAUL_2's Avatar
PAUL_2
Remove the Maf Sensor from the intake plumbing , you should find 2 thin wires in the center of the sensor , use the electrical contact spray to clean them if they are dirty .
Old Mar 3, 2001 | 03:48 PM
jams3's Avatar
jams3
well i talked t a couple of 20 year in the bizz techs
to day and they told me to ck the EGR VALVE AND A CRACK ON EXOST
MANAFOLD ARE CRACKS PRETTY COMMIN ON 5.0. based on what i told them a rolling pinging at about 2800 rpms has eaney body herd of this?
and what in the hell am i looking for on the egr?
I ONLEY HAVE TODAY TO CK IT OUT RAIN STARTING TONIGHT TILL
WENSDAY
THANKS
MARC
Old Mar 3, 2001 | 04:41 PM
KevinT's Avatar
KevinT
You should be able to tell if you have a cracked manifold, you'd HEAR it.
1995 F-150XL SC/SB
http://members.sounddomain.com/blind
5-Star Rated F-150 (Big Stereo)
Old Mar 3, 2001 | 05:19 PM
roscoe's Avatar
roscoe
Old Mar 3, 2001 | 10:12 PM
bgodkin's Avatar
bgodkin
I had the passenger side Exhaust Manifold crack to pieces on a 5.8 liter. You could definatly hear that. Fixed that with a good quality set of headers.
Brad Godkin
1986 F350 CC/SRW
6.9liter/C6
Jimmy Pet
Modular V10 (6.8l)
127
Aug 4, 2019 01:21 PM
sudsmcduff
Jan 12, 2016 06:24 AM
vtjvt
Sep 27, 2015 02:32 PM
ham-n-swiss
Jun 3, 2009 03:59 PM
opeterson
Mar 26, 2006 05:20 PM
