lowering the rear end
Old Mar 27, 2005 | 05:20 PM
riley ruffen's Avatar
riley ruffen
has anybody lower the rear end of a 2005 scab 4x4?
Old Mar 27, 2005 | 09:38 PM
ReForder's Avatar
ReForder
i've seen it posted on here where some blocks were removed from under the leaf springs, necessitating 4x2 leaf spring bolts to be installed over the 4x4 ones. I think this is a more asthetically pleasing setup than raising the front to meet the rear. Keep in mind, that the truck will sag when significantly loaded, but how often does that really happen?
Old Mar 30, 2005 | 02:21 PM
BruceFX4's Avatar
BruceFX4
I did it on a 2004 SCAB. As Reforder mentioned you will need 4X2 ubolts. Support the chassis high enough to remove the rear wheels or to allow the rear end drop a few inches. Place a jack under the side of the axle you first want to start with. Undo the ubolt nuts and remove the bolts. Lower your jack enough to get the cast iron block out from between the axle housing and the spring. Raise the axle up to the spring making sure the pin aligns the spring and housing. Insert the shorter ubolts and tighten enough to assure the pin will not fall out of the hole. Duplicate on the other side. Set the truck on the ground and torque the nuts making sure everything lines up.
Make sure you find a way to note your headlight and fog lamp adjustment before you remove the blocks. You will need to match the adjustment after you drop the rear.
Good luck.
Old Mar 30, 2005 | 04:14 PM
EMB135Driver's Avatar
EMB135Driver
I saw one with the rear lowered the other day, and while it might be more practical for loading and unloading, it looks terrible. The Whole truck looks like a low-rider...all you need is some 22inch crome wheels, a giant subwoofer and some cheesy window tint and graphichs and you will be in business.
Trucks are supposed to be imposing and menacing---Lift the Front....it looks much better.
Old Mar 30, 2005 | 05:36 PM
John Scaro's Avatar
John Scaro
That's a good Idea! Does anyone know if the make a kit to lift the fornt o match? Those HD 22's are going to look good too on it!
Old Mar 30, 2005 | 09:56 PM
ReForder's Avatar
ReForder
I hardly think lowering the rear a touch makes it a low rider, perhaps you saw a 4x2 with a lowered rear. I've seen a Lariat Supercrew in person with the rear lowered and it looked fantastic. Still "menacing", high enough, but no wacky wheel well opening in the rear. Raising the front is great for off-roading, but regardless of what people might say, it will adversely affect the handling of the truck, maybe just slightly. Raise the vehicle=raise center of gravity=dimished handling.
Bruce..how long did it take you to do this? including the headlight re-leveling? Thanks.
Tony
Old Mar 31, 2005 | 03:10 AM
riley ruffen
the reason i want to lower the rear is just so i can reach in a get something out and off the bed. i'm 5' 9 and still can't touch the bed.
does lowering change the way it drives, or anything like that?
Old Apr 1, 2005 | 12:44 PM
BruceFX4's Avatar
BruceFX4
I did not time it, but it was no more than a couple of hours. I did it on the garage floor (no lift) but a did use an impact to remove the the ubolt nuts and run them to save some time. The headlights were a little time consuming as I do not have a socket (4mm?) that fit the adjuster.
I will also guarantee that the back end of my truck is not anywhere near a low rider. There is still a significant gap between the tire and wheel opening and there is a slight forward rake to the truck. At least with the blocks out I can grab (barely) items in the front of bed if they are not too far to the center.
Old Apr 4, 2005 | 07:35 PM
WhiteNight's Avatar
WhiteNight
Do you have the p/n's for the 4 x 2 bolts.Went to the dealer today and he advises there are two different p/n's avail and at $20.00 cdn a pop I want to make sure I get the correct ones.
Old Apr 5, 2005 | 12:30 PM
BruceFX4's Avatar
BruceFX4
I got my ubolts naked, so I do not know the part number ( part of the deal when I bought the truck). There may be different bolts for the heavy duty package. I believe for mine we requested the ones for a shortbed 2wd XLT SCAB and received the right ones.
4ced air lightning
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Dec 4, 2007 09:41 PM
riley ruffen
2004 - 2008 F150
15
Nov 12, 2005 10:27 PM
azviking
Oct 18, 2005 10:02 AM
ibanez13547
1983 - 2012 Ranger & B-Series
Dec 28, 2004 08:44 PM
FTE Ken
Aug 6, 2001 12:07 PM
