lowering rear end
Old Oct 23, 2005 | 09:17 PM
riley ruffen's Avatar
riley ruffen
lowering rear end
has anyone lower the rear end of their truck, and it they did will that efect anything?
Old Oct 24, 2005 | 12:24 AM
Monsta's Avatar
Monsta
Sit. Stay.
It will indeed affect rear ride height! oh wait...
Negative effects due to lowering kinda depend on how you actually go about lowering it. Let's say you use a quality drop kit and just install the rear part of said kit. You shouldn't have any negative effects as far as handling is concerned. Even you ride shouldn't be all that much worse (maybe even better?) unless you are attempting to use as much travel as you had before.
You may corner a tad better due to less understeer and body roll.
How far down do you want to lower it?
Old Oct 24, 2005 | 12:56 AM
fordmarshall111's Avatar
fordmarshall111
I lowered the rear of mine with 2" Belltech drop shackles. It looks great and sits just about level. Only bad thing is a slight vibration at 20 mph, but only with easy acceleration. You can fix that with shims, but to me it's not even worth it. I hardly notice. The Groundforce 2" shackles come with the shims.
Old Oct 24, 2005 | 01:54 PM
kd4crs's Avatar
kd4crs
I lowered mine with the Ground Force 2" drop shackles and it looks and rides great. I had to use the shims to cure a low speed driveline vibration that developed after installing the shackels. Good thing they are included with the kit. Be sure to use lots of grease on the shackles, bushings, and spring mounts or it they will squeak like crazy.
Old Oct 24, 2005 | 08:43 PM
glennbobg's Avatar
glennbobg
How about the front?
Old Oct 24, 2005 | 11:07 PM
kd4crs's Avatar
kd4crs
I decided to leave the front stock. It looks just right. The rear is 1 inch higher then the front with the drop shackles on.
Old Oct 25, 2005 | 03:47 AM
riley ruffen
about 2-3 inches, at least .
Old Oct 25, 2005 | 03:53 AM
riley ruffen
where did you put the shims at? also can you reach in the bed of the truck and pick something up and off the bed? also my truck is a 05 scab 4x4.
Old Oct 25, 2005 | 08:27 AM
kd4crs's Avatar
kd4crs
It lowered the rear almost 2 ". It does make getting things into and out of the bed easier. The shims must go between the spacer blocks and the spring pack with the thicker part of the shim facing the rear of the truck. If you put the shims between the spacer blocks and the axle they don't fit properly. My truck is also a 4X4 SCAB.
Old Oct 29, 2005 | 08:26 PM
riley ruffen
maybe i need to clear something up. all i want to do is to lower my bed. i've heard that you could take the block out between the leaf spring and axle, but i really don't know if that's true.
Old Oct 29, 2005 | 08:44 PM
kd4crs's Avatar
kd4crs
You can take the 4X4 spacer blocks out but you will need to buy the 4X2 u-bolts to replace the longer 4X4 u-bolts. The 4X4 u-bolts are not threaded far enough up to tighten up without the spacer blocks in place.
Old Oct 29, 2005 | 10:52 PM
GLankford's Avatar
GLankford
I also did the Ground Force shackles and they worked great. Better handling, less "hop" and it doesn't look like it's butt is stuck in the air. The shims are a sign to me that these guys aren't cutting corners and know what they're doing- I'd avoid any kit that didn't have them.
Old Oct 30, 2005 | 10:24 PM
riley ruffen
so that's all i need to do, and its not going to effect my driveshaft or anything? i'm not worried about how it looks so much, i just want to be able to pick something up off the bed of my truck.
Old Oct 30, 2005 | 11:30 PM
kd4crs's Avatar
kd4crs
Riley,
I have heard of folks just taking out the spacer blocks and replacing the u-bolts and being just fine. There is always a chance that you might get a driveline vibe when altering the rear height. It just depends on how the pinion angle was set from the factory. It's worth a try just to see if it works. If you get a vibe you can buy some shims for it or put the spacers back in and do the drop shackles. Let us know how it turns out.
Old Nov 12, 2005 | 09:11 PM
fishead's Avatar
fishead
Where's The Best Price On The Ground Force Lowering Shackles?
