Sponsored by: Auxito
2001 4x4 Drop
Old Mar 27, 2005 | 04:59 PM
mikewaller's Avatar
mikewaller
2001 4x4 Drop
I currently have a 2001 4x4 with the "Off Road" suspension. I would like to lower it 4-6 inches. Can this be done safely and keep all the components aligned properly? Joint problems are making it difficult to get in & out of the truck, but I don't want to sell the truck because 1) I own it...not the bank and 2) I like it.
Old Mar 27, 2005 | 05:16 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Mar 27, 2005 | 10:23 PM
preppypyro's Avatar
preppypyro
Might be easier to buy one of them little step ladders haha
Old Mar 27, 2005 | 11:44 PM
Racerguy's Avatar
Racerguy
Hi Mike and welcome
Do you use the 4X4? Can you make do with shorter street type tires or do you need the bigger tires?
I think you're going to have a hard time lowering it as much as you want to. A couple inches would be pretty easy but more than that I'm not sure. Hopefully someone will come along with a better answer for you.
Old Mar 28, 2005 | 06:15 PM
mikewaller's Avatar
mikewaller
Smaller tires
Racerguy,
4x4 is nearly a requirement in Minnesota. I've had 2wd in the past and would prefer that, but the snow, ice, and general nastiness of winters here take that option off the plate. I plan on installing street oriented truck tires when the current ones wear out. I like having a little sidewall on the tire because I actually use the truck (lumber, dirt, etc).
I think preppypyro is onto the right solution...who would have thought?
I saw a spot on one of the TV truck shows where they installed a hidden step. This thing has electrical motors that swing it out when a door is opened. I need to dig around and see who the manufacturer is.
Old Mar 28, 2005 | 07:48 PM
FordPickupMan351w's Avatar
FordPickupMan351w
www.amp-research.com - They put the power step on a dodge ram last week on the Extreme 4x4 on spike tv... hope this helps
germancarsonly
Jun 18, 2014 11:31 AM
buffpilot
Mar 24, 2006 12:48 PM
big_saxy
Aug 1, 2004 11:49 PM
