rust removal by electrolisisi?
Old Mar 27, 2005 | 01:09 PM
learpilot's Avatar
learpilot
I know I read on here some where about a method to use electrolisis to remove rust but I can't seem to find it now. Can anyone point me in the right direction? Anyone used this method to do large pieces (like doors)? Thanks
Old Mar 27, 2005 | 03:32 PM
sancochojoe's Avatar
sancochojoe
here are some detailed instructions and a photo
http://antique-engines.com/electrol.asp
and here is a whole frame having rust removed and how to set it up
http://antique-engines.com/trailer-electrolysis.htm
Old Mar 27, 2005 | 06:03 PM
mr4speedford's Avatar
mr4speedford
http://www.stovebolt.com/techtips/ru..._derusting.htm
This works great! I used baking soda instead of laundry soda and it worked fine. A couple of tips, use the biggest possible electrode you can find. I used steel rebar from home-depot and switched new rods every week. Clean the rods at least 2 twice a week. Bar stock would work real good and you can get that at HD now too. Degrease before putting in. I used a GFI outlet for saftey reasons.
I have seen people do large parts. It takes multiple battery chargers along with a huge amount of water, but once setup would be a easy system to use. Perfectly safe for delicate stuff too. Make sure you primer after taking anything out, it rusts real quick. have fun! -4speed
Old Mar 27, 2005 | 06:20 PM
286merc's Avatar
286merc
It is only truly effective when the surface being cleaned can be "seen" by the electrodes. For this reason it does nothing for derusting deep down in block water passages. For blocks and heads I use the slower but very effective molasses treatment.
MikefromMT
Appearance & Dress-Up
Feb 13, 2026 09:37 AM
browntown3
Feb 9, 2010 10:42 AM
Shiny62
Jul 12, 2005 08:28 PM
hal4rf
Aerostar
Nov 1, 2004 07:10 PM
sancochojoe
Paint & Bodywork
Jan 30, 2004 07:48 AM
