Aerostar Ford Aerostar
alternator removal
Old Oct 27, 2004 | 07:52 PM
hal4rf's Avatar
hal4rf
Exclamation alternator removal
what tool and method can I use to remove the pivot bolt on the alternator in a 1992,3.0L aero star?
Old Oct 28, 2004 | 10:05 AM
himthere's Avatar
himthere
I've got a 94, 3.0. Probably similar. Replaced mine a couple of years ago and only had a problem with the oil fill tube being in the way. Took it out and replaced it afterwards. The pivot bolt may require driving it out with a pin of some sort (maybe a long bolt slightly smaller than the pivot bolt). Remove the nut first. Then drive the bolt out. Yours is probably frozen in. Time will do that.
Old Oct 30, 2004 | 03:52 PM
bear2x2's Avatar
bear2x2
All you have to do is jack up the passenger side a little, take your ratchet and socket and reach in though the cutout in the fender well. remove bolt. No removing the filler tube, no driving the bolt out. Our vans do require some creative thinking to get jobs done don't they.
Old Nov 1, 2004 | 07:10 PM
teg3's Avatar
teg3
I agree with Bear but I had.Remove some small bolts to relocate the filler tube temp.
but the wheel well is correct..Make sure you have the car supported well the nut can be a monster to loosen.and well drop pow..
Ecarlton1991
Aug 28, 2011 01:44 PM
RonW.
2004 - 2008 F150
Feb 27, 2010 05:52 AM
Americanmadeford
1983 - 2012 Ranger & B-Series
May 15, 2008 05:54 PM
z 97ford1
1997 - 2003 F150
Jun 29, 2004 08:42 AM
switchback
Electrical Systems/Wiring
Dec 1, 2003 10:11 PM
