Mounting block heater plug
Old Mar 28, 2005 | 09:43 AM
Hunter40's Avatar
Hunter40
Originally Posted by dlpinkc
How difficult was it to drill that hole in the bumper? I like your install better than the one in air dam (I guess that's the name of the 'thing' under the bumber that I referred to).
It was not very hard. It took about two minutes of drilling in the bumper to make that hole and about 5 seconds of drilling to do the zoodad mod. I just made sure to buy a drill bit that said it was for metal also and used a little oil to keep the blade from overheating. That was probably not necessary however. The metal seemed pretty soft.
Old Mar 28, 2005 | 05:36 PM
DshiftFF's Avatar
DshiftFF
Trailering
It was cake. Get a hole saw from the hardware store. They are good for thin guage metal and wood. The metal is kind of skimpy so I did it with a 12V battery power drill, if that tells you anything. As far as the question goes with do all diesels have BH's All 03's + 04"s do, the 05's only come with the element installed in the block, you have to buy the cord. There are a few northern US states that Come with the cord like Maine Montana and some others I dont remember. If you look in the side of the block in the area of the starter, youll see where the cord attaches to.
