Front Drop Springs
Old Mar 26, 2005 | 09:01 PM
MintHill68f100's Avatar
MintHill68f100
Front Drop Springs
Hey guys and girls, I got a major problem with my 68 F100. I want to lower it and have got the drop shackles for the back leaf springs but can not find any place that has any drop springs for the front.
Old Mar 26, 2005 | 09:07 PM
4Cammer72's Avatar
4Cammer72
lmc has them but it throws the angle of the front wheels off. you can have the beams rebent but the best way is to get drop ibeams.
Old Mar 26, 2005 | 10:52 PM
MintHill68f100
How much trouble would that take do or is there any other option?
Old Mar 27, 2005 | 02:08 AM
stevef100s's Avatar
stevef100s
No other option.
Old Mar 27, 2005 | 09:52 AM
4Cammer72's Avatar
4Cammer72
i will get a lot of flack for this but i cut my coils and had my beams rebent at a frame shop. they rebent and aligned them for $145. alot cheaper than the $500 for the drop beam setup. i'm very happy with the result.
Old Mar 27, 2005 | 05:43 PM
MintHill68f100
What about drop spindles? Has anyone ever heard of doing that?
Old Mar 27, 2005 | 06:33 PM
stevef100s's Avatar
stevef100s
Nobody makes a drop spindle for Fords with I beams.
Old Mar 27, 2005 | 06:37 PM
MintHill68f100
thanks for the info! it has been really frustrating in only finding ways to drop the back and not the front. does bending the beams weaken the frame though?
Old Mar 27, 2005 | 06:53 PM
4Cammer72's Avatar
4Cammer72
it has to be bent cold. if you heat them it weakens them.
Old Mar 27, 2005 | 07:02 PM
MintHill68f100
so any metal shop could really do it or is it somethin u can do urself?
Old Mar 27, 2005 | 09:29 PM
4Cammer72's Avatar
4Cammer72
ive heard of a few guys doin it themselves but you are messing with the alignment of the front suspension. without the proper tools to make sure you keep everything exactly straight i think it should be left to the pros. a good heavy truck repair shop or frame shop should be able to do the job.
Old Mar 28, 2005 | 01:08 AM
stevef100s's Avatar
stevef100s
You guys need to take a look at your stock front suspension. There is very little room between the I beam and the rubber bump stop. If you install shorter springs or cut yours down, then you are reducing your suspension travel even more then the few inches that you have. That is why the only approved method of front lowering, is with drop beams. Ford made a set just for the 93-95 Lightning, to get it down a little. If it would have been ok to cut the springs and bend the beams, don't you think they would have? A dropped front end looks good, but what good is it if you only have an inch of suspension travel?
Uni Moe
22
Mar 21, 2015 03:55 PM
johnnydmetal
Sep 23, 2006 08:46 PM
