*&%$% MSDignition.com
and still no answer.
Did any of you guys ever contact them? Did they respond? Do I have to call them?
1988 F-150, 5.0L 302ci, 5spd, SuperCab. Shorty headers, K&N filter, Accell 300 8.8mm race wires, Accell supercoil, Accell rotor+cap, Bosch +4 Platinum plugs, RanchHand bumper. Soon (hopefully): MSD 6a ignition and dual exhaust.
I got the same thing when I tried to get information on the white face guages for the ford rangers that look identical to the guages in my 88 model. I finally got mad, and sent an email to eveyone listed on their website! Boy oh boy, I finally got an answer! And a faxed copy of the guages!
1988 F-150, SWB, 5.0 EFI (formerly 4.9 EFI), M5OD 5 speed, 3.08 gears, Summit shorty truck headers, Custom built Flowmaster exhaust system. Force 4 LP6000 lightbar, Federal signal PA-300 100 watt siren, Icom IC-V100 50 watt mobile radio.
1965 F-100 (just purchased 1/18/01), SWB, 390, C-6 auto. Dual exhaust, Not much else to do to it.
Can see both below.
[link:www.geocities.com/hotrodford_88/|Hotrodford_88's Webpage]
This was the issue with my 6A.
Xaviar
96 F-250HD 4x4 460/E4OD 4.10
Banks Power Pack, Trans Command
MSD 8227 Coil, MSD 32199 8.5 Wires, MSD 6A
https://www.ford-trucks.com/dcforum/80_96/4393.html
It starts fine, but stumbles and eventually dies at idle. It starts rough, then almost dies, picks up RPMs to run rough again, stumble, almost dies, picks up RPMs and so on for a couple of times until it eventually stumbles to a halt. It seems to drive halfway ok, though (but I just drove it around the block). It'll stay running if I have the foot on the gas pedal, too. I've never bolted the unit down, but that shouldn't make much of a difference, should it?
I guess I'll have to call them...
1988 F-150, 5.0L 302ci, 5spd, SuperCab. Shorty headers, K&N filter, Accell 300 8.8mm race wires, Accell supercoil, Accell rotor+cap, Bosch +4 Platinum plugs, RanchHand bumper. Soon: MSD 6a ignition and dual exhaust.
Red to positive side of battery (directly) and black wire to negative wire junction block on fender apron next to battery (or also directly). If wires are to short to reach, lengthen them. I had to lengthen mine for it to reach. It is imperative that you connect the positive (red 6A wire) to the battery and NOT starter relay switch.
After re-wiring mine this way it worked EXCELLENT.
Let me know if this helps. I will email you the response I got from MSD. So, check your email.
Xaviar
Banks Power Pack, Banks Trans Command
Let me know if my suggestion works. Your negative wire should be ok going to chassis ground but the red wire needs to be moved to the positive side of battery.
Xaviar
Thanks again!
Bjoern
MSD finally contacted me last night and also suggested to go to the battery posts directly. So I cleared the computer once again, hooked it up directly to the pos. and neg. battery posts (not to starter relay post, not to chassis) and it worked!
It doesn't make much sense to me, as physically it shouldn't make much difference, but now it's working so I don't care!
Thanks for all your help!!
Bjoern
1988 F-150, 5.0L 302ci, 5spd, SuperCab. Shorty headers, K&N filter, Accell 300 8.8mm race wires, Accell supercoil, Accell rotor+cap, Bosch +4 Platinum plugs, RanchHand bumper, MSD 6a ignition. Soon: Dual exhaust.
If you are able to give your opinion on the 6A and its performance or lack thereof please do. I am considering this as one of my next upgrades.
Thanks,
WHaynes,
93 F150 4.9L 4x4
4" ProComp StII Lift
BFG 33in 4.10's
Detroit TrueTrac's
You might check out a couple of threads here about spark plugs. My experience has been that some later model Fords like only Autolites or Motorcrafts. Especially after the years 88 on up.
Just my .02 cents
Good luck
Xaviar
1988 F-150, V8, 5.0L (302ci), 5spd, SuperCab. Shorty headers, K&N filter, MSD 6a ignition, Accell 300 8.8mm race wires, Accell supercoil, Accell rotor+cap, Bosch +4 Platinum plugs, RanchHand bumper. Soon: Dual exhaust.
http://brembs.net/cars/FordPU.html
Bjoern
