1978 - 1996 Big Bronco
Shock suggestions
Old Mar 23, 2005 | 08:33 AM
Will_01_GT's Avatar
Will_01_GT
Originally Posted by jbondi
When I bought my 94 Bronco, it had Monroe Gas Magnums. They were bad!! I replaced them with KYB Gas-A-Just shocks. When I removed the Magnums, I could compress them very easily. On the other hand, the KYB Gas-A-Just were very strong. Once I got them installed, I noticed the truck actually sticking to the ground and they actually raised the body a little bit. When going around a turn in the road, the truck did not lean. However, the Gas-A-Just shocks made you feel every little imperfection in the road!! They were so stiff that they were rattling everything in the truck, including me!! About a year ago, I replaced the Gas-A-Just shocks with KYBs GR-2s. Better ride all around. Check out the Tire Rack. They seem to have the best prices.
I was told that KYB OEMs Ford shocks.
KYB's Rock !!!!!!
I have 6 on my 96 EB and I love the ride
Old Mar 23, 2005 | 08:47 AM
jbondi's Avatar
jbondi
Originally Posted by Will_01_GT
KYB's Rock !!!!!!
Will,
Which KYBs do you have??
Old Mar 23, 2005 | 08:51 AM
Will_01_GT's Avatar
Will_01_GT
Will,
The KYB white gas a adjust shocks
http://www.tirerack.com/suspension/s...s-A-Just+Shock
Old Mar 23, 2005 | 10:02 AM
poffutt's Avatar
poffutt
I have a question while were on this subject. I just bought Rancho RS 6000 for my front quad. I have the Rancho 6" lift. The shop that put them on put the same size on both sides in the front. They said this is correct. But the shock closest to the rear looks like it is pushed up so high that is looks like it only has about 3" for expansion. Does anyone know what Rancho sizes shoud be on the front quad on a 6" lift?
Old Mar 23, 2005 | 10:57 AM
kaised's Avatar
kaised
I have 4 Bilstiens on my 96 and I have no complaints. They are the best riding shock I've ever used. I had Monroes on my Bronco prior to this and didn't like them, they felt like they'd gone bad after about a year of use. I used Rancho 9000's on my lifted explorer and they were pretty good but I still like the feel of the Bilstiens better.
Old Mar 23, 2005 | 01:50 PM
JBronco's Avatar
JBronco
Originally Posted by gjordan456
thats a good question, the shocks are stamped with a small ford logo but this dos'ent nessesarlly mean they were made by ford, regardless they work great, the other thing on this subject, in the past I've bought shocks for trucks with tired and overloaded springs and did'ent notice much improvment in the ride, they were still bouncy, on my bronco, it has newer coil's and rear springs and I think with these and the new shocks is what gives the truck such a good ride...
I think that my springs are fine. The truck has had a pretty easy life for a Bronco, it still sits like new, higher in the back for whatever reason Ford designed it that way for; and it is not bouncy at all.
PS - I want a soft street and highway ride and can give up the maximum off road performance. I'm not jumping the truck or doing Rubicon. I'm sure that a soft street riding shock will be fine for my type of off roading, moderate dirt and mud trails and snow.
Old Mar 23, 2005 | 06:05 PM
JBronco's Avatar
JBronco
BTW here is a link to a pic of the shocks that are on my Bronc now. They were on there when I got it. The label is not legible, but someone here said that they were not stock.
https://www.ford-trucks.com/user_gal...=71443&width=2
I also noticed that one of the shocks is compressed more than the other, so I guess that this is how it is supposed to be (someone earlier was commenting about that).
Old Mar 23, 2005 | 06:10 PM
tex94F250's Avatar
tex94F250
Shocks, stock?
JB,
I had a dual shock setup and looking at those pictured, I don't think that they are stock. Did some checking with Brad at Akins Ford. He recommends KYB (25 years there +), says most bang for the buck and to shop them on the net.
Old Mar 23, 2005 | 06:45 PM
94 XLT White/ Silver 302's Avatar
Proffutt the front and rear quad shocks are different. If you call Summit Racing they will give you the RS#s for the shocks the numbers are stamped into the shell of the shock so you will be able to tell which shocks are wrong by the part number. Hope this helps.
rudder9's Avatar
rudder9
I Have A 95 . I Replaced My Stock Shocks With The Rancho Rsx's And I Love Them.i Too, Do Mostly On Road Driving And They Improved The Handling Quite A Bit.(i Also Did My Entire Front End With Energy Susp.bushings) That Also Helped With The Handling. I Have Had Them On For About 3000 Miles . Off-road They Also Performed Very Well. I Reccomend Them Highly. Fyi A Friend Of Mine Owns A Speed Shop,and He Has Them On His F-150. He Likes Them Better Than The Edelbrock Shocks He Has On His Lightning.
Old Mar 23, 2005 | 10:56 PM
JBronco's Avatar
JBronco
Do you mean that, of the two shocks on either side of the front, and disregarding the rear of the truck for a moment -- do you mean that each of the two on the front is different? Like a "front" front shock and a "rear" front shock - one in front of the spring and one behind the spring? Are you saying that they are different then? They do LOOK different, as far as the size of the boots on mine or at least how far they are compressed. The "rear" front shock looks compressed about twice as much as the "front" front shock. You can see this in my picture.
You did say that _something_ was different. So did you mean what I asked above, or did you mean that the shocks that go on the rear of the truck are different than the shocks that go on the front of the truck?
Please let me know about this before I order the wrong thing!
Old Mar 23, 2005 | 11:37 PM
Kep4's Avatar
Kep4
Jäger
My 94 Bronco with the quad shock set up has two different shocks on each front side, a front set and a rear set. They are different lengths and mount differently. The front shock is stud mounted and the rear shock is flange mounted to the radius arm. Choose the manufacturer you like and look through their catalog and you'll see two different shocks listed for the "quad front end" on a Bronco. Hope this helps.
Old Mar 23, 2005 | 11:52 PM
  #28
nwmud's Avatar
nwmud
I agree about the Monroe Shocks - mine were broken. Ranchos are ok if you like stiff rides. I replaced my Monroes with a cheap shock until I find the ones I really want to run.
Ritch
Old Mar 24, 2005 | 11:30 AM
  #29
JBronco's Avatar
JBronco
So far after reading all of these I am leaning to stock Ford, Edelbrock, and Bilstein. I will read up on their qualities and prices and see what I can figure out.
Old Mar 24, 2005 | 11:59 AM
  #30
atvr's Avatar
atvr
I had a 84' full size Blazer some years ago. When I bought it, it had the Monroes on it. They were wore out so I replaced them (all six) with Rancho 5000. I hated the ride. That truck would find every pebble on the road and sway in a light breeze. My 95' Bronco has OE shocks and the ride is still great. When they need replacing I will install the same.
sfc2001
22
May 9, 2023 02:36 PM
Rusty_S
Oct 20, 2015 07:15 PM
DarylWork
Modular V8 (4.6L, 5.4L)
Apr 15, 2015 06:20 AM
TexasShadow
Jan 9, 2014 01:56 AM
biscuit141
1997 - 2003 F150
Aug 4, 2013 06:22 PM
