Understanding Haynes Manuals
Haynes: Rotate anticlockwise.
Translation: Clamp with visegrips then beat repeatedly with hammer counterclockwise.
Haynes: This is a snug fit.
Translation: You will skin your knuckles!
Haynes: This is a tight fit.
Translation: Not a hope in heck, bucko!
Haynes: As described in Chapter 7...
Translation: That'll teach you not to read through before you start; now you are looking at scary photos of the inside of a gearbox...
Haynes: Pry...
Translation: Hammer a screwdriver into...
Haynes: Undo...
Translation: Go buy a BIG can of WD40...
Haynes: Retain small spring...
Translation: "Jeez what was that, it nearly took my eye out!"
Haynes: Press and rotate to remove bulb...
Translation: "OK - thats the glass part off, now use some good pliers to dig out the base...
Haynes: Lightly...
Translation: Start off lightly and build up till the veins on your forehead are throbbing...
Haynes: Routine maintenance...
Translation: If it isn't broken... it's about to be!
Haynes: One spanner rating.
Translation: Your mother could do this... so how did you manage to botch it up?
Haynes: Two spanner rating.
Translation: Now you may think that you can do this because two is a low, tiny, 'little number... but you also thought the wiring diagram was a map of
the Tokyo underground.
Haynes: Three spanner rating.
Translation: OK - but don't expect us to ride in it afterwards!
Haynes: If not, you can fabricate your own special tool like this...
Translation: hahahahahahahahahahahahahahahahahahahahahaha!
Haynes: Compress...
Translation: Squeeze with all your might, jump up and down on, swear at, throw at the garage wall, then search in the dark corner of the garage for
while muttering "Piece of junk" repeatedly under your breath.
Haynes: Inspect...
Translation: Squint at really hard and pretend you know what you are looking
at, then declare in a loud knowing voice to your wife "Yep, as I thought,
it's broke!"
Haynes: Carefully...
Translation: You are about to cut yourself.
Haynes: Retaining nut...
Translation: Yes, that's it, that big spherical blob of rust.
Haynes: Get an assistant...
Translation: Prepare to humiliate yourself in front of someone you know.
Haynes: Turning the engine will be easier with the spark pugs removed.
Translation: However, starting the engine afterwards will be much harder.
Once that sinking pit of your stomach feeling has subsided, you can
start to feel deeply ashamed as you gingerly refit the spark plugs.
Haynes: Refitting is the reverse sequence to removal.
Translation: But you swear in different places.
Haynes: Prise away plastic locating pegs...
Translation: Snap off...
Haynes: Using a suitable drift...
Translation: The biggest nail in your tool box isn't a suitable drift!
Haynes: Apply moderate heat...
Translation: Placing your mouth near it and huffing isn't moderate heat.
Haynes: Index
Translation: List of all the things in the book but the thing you want to do!
Every car I sell or work on has one too because I have the customers buy one.
Translation: Someone from the UK or Australia wrote this stupid book!.
Translation: It ain't going in without a special driver...
Translation: I wonder who I can wish this on, without paying much extra?
Translation: Chicken dung sucker wanted to go play golf that day, instead of writing a proper manual...
Haynes: Pry...
Translation: Ease it out somehow so it doesn't become very expensively destroyed
Haynes: Undo...
Translation: Take a picture first, write it down on a clipboard, and take note of it - because it will KILL your truck when you forget about it later.
Translation: You ain't gonna find this thing at AUTOZONE...
Translation: Wear gloves! It's gonna break...
Haynes: Lightly...
Translation: Whatever it is - it's expensive and hard to find.
Translation: You're going to BUY THIS ALOT. Get used to it...
Translation: An idiot working for a lube house does this all day, all week.
Translation: You need air tools, Bubba
Translation: Replace it entirely, wish the removal on someone else, or use dynamite.
Translation: Those cheap boogers couldn't think of a way around it...
Haynes: Compress...
Translation: You are about to involve three of your friends in an action that they don't want anything to do with...
Haynes: Inspect...
Translation: Throw that used up piece of junk out, and buy new
Translation: This is going to hurt...
Translation: "C. R. - Get the TORCH lit...."
Translation: Witnesses are required...
Translation: Like I didn't know that the plugs could tell a lot of the story...
Translation: But much easier, since now you realise where the manual writers had their heads stuck where the sun don't shine.
Translation: Pry out keyways, and store them where you absolutely cannot lose them.
Translation: Find something that won't mushroom it...
Translation: Tick off the ex-wife, and have her stand next to it for ten minutes!
Haynes: Index
Translation: The short list, of what you don't need to know!!!!
~Wolf
use a 2-jaw puller
Translation: get the BIG ****** sledge hammer
2WD shown, 4WD similar
Translation: Sucker!
Reassemble in reverse order
translation: you'll have at least 2 bolts left over.
Translation: It's probably cursed.
Haynes: "Repairs to (this unit) should be referred to qualified service personnel"
Translation: The Haynes tech wasn't fully certified.
Haynes: "Ensure that the airbag system has been disconnected."
Translation: You're about to spend two days tearing out the whole dashpanel assembly by doing it their way.
Haynes: "An alternative method is the following..."
Translation: They figured out an easier way to do it on the second try (Q: Why did they re-do it?)
Haynes: "The following information covers most models - "
Translation: Good odds this dang book don't have the straight info...
~Wolf
PS: Have you ever really looked at the picture of the "Haynes Team at Work" on these manuals? Do they really look like they know what they're doing? I'll give you a clue - the obvious "Mechanic Dude" is never dirty or greasy...
My other gripe is that to get a full set of wiring diagrams, you need a Chiltons and a Haynes each, for what you want to work on. Each seems to be missing what the other covers, unless neither have what you need. When that happens - a very pricey manual from the dealer is the only way out...
