Sending unit test points?
Old Mar 21, 2005 | 09:47 PM
87f150xlt's Avatar
87f150xlt
Gas gauge read totally empty when switched to front tank, I think it's the Sending unit in the front tank. I like to find out testing points at connector top of the fuel tank. I like to test fuel gauge and sending unit. diagram, wire color, location, test method and such would help alot. Thank you in advance,
Old Mar 21, 2005 | 10:21 PM
schafer1's Avatar
schafer1
Make sure your ground wires are clean and tight. start there first then go from there.
Old Mar 22, 2005 | 07:36 AM
87f150xlt's Avatar
87f150xlt
Thanks for your reply, where is this ground wires located again?
Old Mar 23, 2005 | 10:43 AM
87f150xlt's Avatar
87f150xlt
Should I attach a new ground strip on chassis to gastank? but if the ground is the problem shouldn't my gauge read full instead of zero? It's been raining here so I didn't get to work on it but what if I just disconnect the connector on top of the gastank? the fuel guauge should read full? and when blue/yellow? wire is grounded the gauge should read empty?
Help me out! I have a Chilton manual and 87 factory electrical/vacumm manual but seems very different for 92.
diesel77
Jul 28, 2020 11:52 PM
sparkyj
17
Jan 22, 2016 02:10 PM
JamesHendrix
May 27, 2014 08:31 PM
wally2117
Electrical Systems/Wiring
Aug 2, 2006 10:54 AM
hotrodmerc
Bronco II
21
Jan 14, 2005 08:58 AM
