Help Please
Old Mar 21, 2005 | 07:55 PM
pooh_bearnd's Avatar
pooh_bearnd
Exclamation Help Please
i HAVE A PROBLEM WITH MY ELECTRONIC SHIFT
CONTROL. THE BLUE WIRE/RED LINE IS CONNECTED BUT THE 3 NEXT TO IT ARE NOT. A BLUE WIRE, A ORANGE WIRE/BLUE LINE AND A WHITE WIRE/BLUE LINE. IN WHAT ORDER DO THESE GO?
Old Mar 21, 2005 | 08:38 PM
Dealford's Avatar
Dealford
Absolutely Blinding !!!!!!!!!!!!
What are the specs of your truck? Year, model, engine & tranny?
AL.
Old Mar 22, 2005 | 05:36 AM
pooh_bearnd
Question sorry
1993 ford explorer 4.0 automatic tranny
Old Mar 22, 2005 | 05:36 PM
Franklin2's Avatar
Franklin2
Can you make your font size a little smaller to make it easier to read? Thanks.
I assume you are looking at the dash control itself. There is a dash control, and computer module, and then the switch/motor mechanism on the transfer case.
The only wires that I can find that somewhat match your description are on the "shift control switch".
Lightblue/red- is power for the dash light in the switch
Darkblue, orange/lightblue, white/lightblue, and also a brown/white, and a grey all go from the switch to the "electronic shift control module". This is the brain that controls the whole system.
Old Mar 22, 2005 | 06:41 PM
pooh_bearnd
[/B] there is a connector for 8 wires, 5 of which the wires are connected. I need to know which wires go into the other three holes.
*ooo
Old Mar 22, 2005 | 10:18 PM
Franklin2's Avatar
Franklin2
The only way I know to figure it out is to do continuity test through the switch.
With the switch in "HI", the red/yellow will be connected to the darkblue, and the black will be connected to the grey.
With the switch in the middle position(I assume this is 2wd?), the red/yellow will be connected to the white/lightblue.
With the switch in "LOW", the re/yellow will be connected to the orange/lightblue, and the black will be connected to the brown/white.
Old Mar 23, 2005 | 07:47 AM
pooh_bearnd
whats the point in having a electronic control module if the suv is 2 wheel drive?
Old Mar 23, 2005 | 12:00 PM
Franklin2's Avatar
Franklin2
If you are referring to the statement above that I made in my post, I meant that the wiring diagram shows the switch to be 3 position. 2 of the positions are labeled Hi and Low, and the middle position was not labeled at all, so I was assuming in this position, the vehicle was in 2wd.
I also assumed when you stated your original problem, that "shift control" meant your 4wd switch. If your vehicle is 2wd, then you need to explain what a "shift control" is.
Old Mar 24, 2005 | 06:51 PM
pooh_bearnd
Thanks Everyone For No Help. I Went To My Neighbors Who Also Has A 93 And Checked His Wiring. I Just Thought This Would Be Quicker But No One Came Up With The Right Answer In Four Days So Why Wait Any Longer
