i HAVE A PROBLEM WITH MY ELECTRONIC SHIFT CONTROL. THE BLUE WIRE/RED LINE IS CONNECTED BUT THE 3 NEXT TO IT ARE NOT. A BLUE WIRE, A ORANGE WIRE/BLUE LINE AND A WHITE WIRE/BLUE LINE. IN WHAT ORDER DO THESE GO?
Can you make your font size a little smaller to make it easier to read? Thanks.
I assume you are looking at the dash control itself. There is a dash control, and computer module, and then the switch/motor mechanism on the transfer case.
The only wires that I can find that somewhat match your description are on the "shift control switch".
Lightblue/red- is power for the dash light in the switch
Darkblue, orange/lightblue, white/lightblue, and also a brown/white, and a grey all go from the switch to the "electronic shift control module". This is the brain that controls the whole system.
If you are referring to the statement above that I made in my post, I meant that the wiring diagram shows the switch to be 3 position. 2 of the positions are labeled Hi and Low, and the middle position was not labeled at all, so I was assuming in this position, the vehicle was in 2wd.
I also assumed when you stated your original problem, that "shift control" meant your 4wd switch. If your vehicle is 2wd, then you need to explain what a "shift control" is.
Thanks Everyone For No Help. I Went To My Neighbors Who Also Has A 93 And Checked His Wiring. I Just Thought This Would Be Quicker But No One Came Up With The Right Answer In Four Days So Why Wait Any Longer
