changing starter
Old Mar 21, 2005 | 06:01 PM
zonkahead's Avatar
zonkahead
changing starter
have a 95 explorer 4x4. whats the trick in pulling the starter out. the drive shaft is in the way..help!!!!!!!
Old Mar 21, 2005 | 07:51 PM
black wolf's Avatar
black wolf
If you cant take the starter off the way it is then you may have to disconnect the drive shaft off..make sure you mark the driveshaft and transfer case flanges with yellow paint or chalk before you unbolt it . alignment is a must or you will throw everything off..ps make sure you disconnect the battery cables to play it safe as well. i hope this helps
Old Mar 21, 2005 | 11:35 PM
zonkahead's Avatar
zonkahead
there's got to be a better way. the last time i changed it, i ran into the same problem, but some how i was able to free it thru. but can't recall how i did it.
Old Mar 22, 2005 | 03:48 AM
marragtop's Avatar
marragtop
I put a starter on my '95(4.0 mtr) last year. Didn't have to do anything with the drive shaft. I believe you just need to **** it at an angle to clear everything. Here's what the book says: http://autozone.com/servlet/UiBroker...3d800b8d4a.jsp
Old Mar 22, 2005 | 03:19 PM
sjwoody's Avatar
sjwoody
I haven't changed a starter (yet) but how 'bout this thought...
Jack up the vehicle on the frame, causing the front end to sag, dragging the driveline down a little, which should give you clearance.
Just a thought....
Old Mar 23, 2005 | 01:18 AM
zonkahead's Avatar
zonkahead
thanx for the suggestions, jacking the truck up makes sense. thanx again.
Old Mar 31, 2005 | 03:12 AM
zonkahead's Avatar
zonkahead
found the trick to the starter removal. you have to remove the selenoid cable first, then cocked it a little and it fell right out. no jacking, no drive shaft removal, hope this helps some one else out. it definately had me scratching my head.
med0989
2004 - 2008 F150
Feb 23, 2017 09:39 PM
Jeff heine
Dec 14, 2016 01:34 PM
Badboy4wd
Oct 16, 2016 11:16 AM
ronspolv
Sep 10, 2016 01:20 PM
LloydH
Aug 8, 2015 08:19 AM
