Compression Check
Old Mar 21, 2005 | 01:34 PM
bhaggerton's Avatar
bhaggerton
Compression Check
I did a compression check on my 1990 Ranger 4x4 2.9L V-6. Five of the cylinders registered the same. No. 3 didn't register any compression. Now, do I need a valve job or possibly a re-ring job. The truck doesn't use oil and doesn't smoke any. It doesn't have any power going up the mountain where I live and the gas mileage went way down. Any help appreciated....Thanks!
Old Mar 21, 2005 | 03:01 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
No compression as in zero? It would take severly worn or maybe broken rings, a hole in a piston, or a major burnt valve to do that; I've never seen a case of zero compression on one cylinder. I would also be wondering if a valve is stuck open a bit; enough to cause a major compression loss yet not enough to make contact with the piston ( ). In your case with no oil consumption, I'm thinking valve issues.
Did the problem come up all at once or was it gradual and over time? Is there the sound of rushing air in the exhaust or at the intake indicating a bad valve and thus creating the noise? What did the plug on the dead cylinder look like? Any chance you didn't do a good test on the dead cylinder?
Old Mar 21, 2005 | 03:16 PM
G2IC_Wraith's Avatar
G2IC_Wraith
Ditto what he said. Also like he asked, "What does that plug look like"? I would think it looks like crap. A ring problem "should" result in a smoker, and oil consumption, but still have some compression. Maybe that piston is on vaccation. Seriously, a stuck/bent valve is your best bet.
Old Mar 21, 2005 | 03:20 PM
bhaggerton's Avatar
bhaggerton
Compression Check Reply
Bill, thanks for your response. The problem has been gradual over a short period. I did the test three times....it would register a little, but not enough compared to the other cylinders. It was not completely zero! I did have a blown head gasket about 6 months ago, which I repaired. Thanks again!
Old Mar 21, 2005 | 09:07 PM
Ken00's Avatar
Ken00
I would lean towards a valve issues but I have seen a toasted piston in a well maintained 2.9, I think it was tbird's (eric) truck.
Old Mar 21, 2005 | 09:15 PM
stuart1's Avatar
stuart1
Do an air check and listen for the noise.
Oil filler? rings or piston.
Tail pipe? exhaust valve.
Throttle body? intake valve.
Radiator? head gasket.
hotbob300
Dec 6, 2012 04:45 PM
bakershere88
New Member Introductions
Oct 1, 2007 02:41 AM
Mogul
1947 and Older Ford Trucks
Feb 29, 2004 08:15 PM
mgessner
Apr 27, 2001 09:23 AM
steakman_usaf
17
Aug 23, 2000 10:41 PM
