compression on 4.0 and heating problem
Old Dec 3, 2012 | 08:17 AM
hotbob300's Avatar
hotbob300
hi. checked compression on my 93 explorer limited and got 170lbs on 4 clyinders, and 160 on rear cylinders. is this good or bad? can anyone tell me if it's time to rebuild, or maby a valve job. runs pretty good but get a little hot when towing my 16 ft. boat. it starts hard, and runs bad for a while, after unloading boat. temp guage does not get in the red, but you can feel and smell the heat from the front of the vehicle. and it doesn't seem to boil over. i checked plugs, they all are on the white side. is this an indication of running hot? thank's for any help you may give me. bob.
Old Dec 3, 2012 | 08:27 AM
senix's Avatar
senix
10 lbs difference is not anything to worry about and cause any rebuild in my mind.
White plugs does indicate it is running hot. You could possible change to a different plug but that does not appear to be the best solution.
Address why it is running hot..have you looked into your thermostat? Is it bad. Is it of a higher temp setting then it should be?
Coolant maintance? When was the last time you did a flush? Is the coolant up to snuff?
Clutch fan? Is it working as designed?
16ft boot. What is the total gross of the boat/trailer/everything when hooked up to the explorer? Are you over loaded?
Old Dec 3, 2012 | 03:29 PM
hotbob300's Avatar
hotbob300
overheating 4.0
yes i have new thermostat, new coolant, no clutch fan, coverted to 2 stage electric. boat is very small and light. today i tore down the top of motor, and found a gasket out of place on the intake, i think that will cure the rough idle, but i don't think it will cure the heat problem. i put the thermostat in hot water, it opens just fine. i think while i have it torn down, i'll do a valve job. put it together and see what happens. thank's for your reply. i appreciate it. bob.
Old Dec 3, 2012 | 03:43 PM
aquanaut20's Avatar
aquanaut20
The white plug tips were an indicator of lean running, this in turn causes hot burn...
Does your CEL not work??
Why did you not use an IR gun to check temps ??
Connect a LIVE DATA SCANNER, and do a diagnostic scan...
I think you are wasting $$$ and time tearing heads off without further diagnostics...... Philip
Old Dec 3, 2012 | 03:51 PM
senix's Avatar
senix
when you tested the thermostat..at what temp did it open.
Also you said you have an electric fan on it now...I suspect that is the real issue. What about the shroud? still have that on?
I'd suggest going back to the orginal design.
Old Dec 3, 2012 | 05:19 PM
hotbob300's Avatar
hotbob300
hot 4.0
hi aquanaut20, just read your thread on my 4.0. great stuff. a freind of mine told me the same thing, that a vacuum leak can cause it to run lean, and hot. i think tommorrow i will put it back together and see how it runs. i don't know much about the testing things you are suggesting. cel,ir,and so on, but i can find out. thank's a lot, i think you have saved me some money.
Old Dec 6, 2012 | 04:45 PM
hotbob300's Avatar
hotbob300
hot 4.0
hi, well i put my 4.0 back together, without taking the heads off. after finding a bad gasket on the intake. it now runs really good, and i don't feel the heat, when walking by the front end of the car, like i use to.the final test will be when i pull the boat again. i wan't to than'k everyone that replied to my thread. it's hard to believe that a vacuum leak, can cause this overheating. i hope this maby will help someone else out there, with a similar problem. bob.
Dixieland Diesel
Feb 12, 2013 11:06 AM
roree
Aerostar
Dec 23, 2007 01:07 AM
RedRooster77
1978 - 1996 Big Bronco
Apr 16, 2007 05:28 AM
maint_manager
Jul 13, 2005 06:35 PM
Big Wood50
Jan 2, 2004 07:30 AM
