I am checking my compression tonight to see if I can verify a blown head gasket. (see post on the FE board) In this case, it probably doesn't matter, since I am looking for 2 cylinders lower than the rest. But, should I check the compression after running the engine for a while, or when it is cold? I have been told to check compression, then squirt a little oil in the cylinder and check again to distinguish between leaks on the upper or lower end.
Check it both ways. Take the cold readings and then take the warm readings. If there is no change in the readings on any cylinder then I would say that there is a blown head gasket. Warming up the motor allows the rings to swell, like all metals do when they are hot, to fill the cylinder better. But if you have a blown head gasket you will find water in your oil or oil in your water. I have never seen one that didnt. As far as oil in your cylinder then testing?? Let me know how it goes, I would think that would be the same as a warm test unless your rings are really gone.
Be carefull if you put oil into the cylinder's when doing your tests, I have seen things break from the pistons in the cyliners going "hydraulic" due to the better sealing caused by the oil!
>Hi,
>caused by the oil!
>My two cents,
>-Brents
Only use about a teaspoon to check if it's rings or a valve/head gasket problem... A teaspoon shouldn't make the pistons go "hydraulic". If compression goes up temporarily, it's the rings or cylinder... if not, it's most likely a valve/head gasket problem. Hope that helps.
Oh yeah... if you have two adjacent cylinders that are low, it's probably got a blown head gasket between those two cylinders, sounded like you already knew that though. Good luck...
