40-45 MPH spudder?
Old Mar 21, 2005 | 12:24 AM
blueovalwonder's Avatar
blueovalwonder
40-45 MPH spudder?
i have a 94 F150 with a 300.....lately i noticed when i was crusin though town about 40-45..if i wasnt accelerating or completely off of the gas...just kinda holding it there the truck would spudder...kinda like a clogged fuel filter or bad u joints...any ideas...anyone had this happen?
Old Mar 21, 2005 | 12:44 AM
befuddledguy's Avatar
befuddledguy
Check FPR / Fuel Filter
I had a similar problem in my 93 and it turned out to be my Fuel Pressure Regulator. My truck ran fine most of the time but had hesitation and sputter at certain speeds. The fuel filter was extremely clogged and that helped, but didn't cure the problem so spent a day troubleshooting the entire fuel system and it turned out to be the FPR - which was replaced for free by Ford due to a recall on it for that year truck. So you might check those two things to start with -
BigBlu 93F150 5.8
Old Mar 21, 2005 | 12:46 AM
blueovalwonder
i bought a new fuel filter the other day...but neither a buddy of mine or myself couldnt get the fuel filter off...i have a shop and have all the fuel line tools...none would take the clips off..
Old Mar 21, 2005 | 01:11 AM
befuddledguy
There is a solution
I went through the same thing at my dads shop when I replaced the fuel filter. He's got just about every tool known to man, but not the one needed for removing the forward clip on the filter. Eventually he got it off by bracing the filter on the frame rail and beating the crap out of it with a rubber mallot. It was later that day we discovered there is a special tool made specifically for the ford in-line fuel filters/fuel lines available at most auto-stores for 5 or 10 bucks. Hope this helps...
If you want to check your vehicle for recalls on the FPR you can go to the Ford Web-Site and enter your vin # -
Good Luck!
Old Mar 21, 2005 | 07:16 AM
firstonraceday's Avatar
firstonraceday
I had the same problem on my '93. In this case I replaced the throttle position sensor and that cured the stutter.
Old Mar 22, 2005 | 12:08 AM
blueovalwonder
i really do appreaciate the help....but again tonight it did it again...i kinda think it is in the driveline....like u joints or some play in the output shaft in the tranny...if im in low and going about 2-4 mph...and just let off of the gas...the truck kinda starts to hop..like a crawl sortof...what could that be..?
marine57_4
6.7L Power Stroke Diesel
Jan 17, 2012 08:32 AM
6.7Fan
36
Jul 30, 2011 11:27 PM
bronco power 79
1978 - 1996 Big Bronco
Jan 12, 2011 12:33 PM
OAGES
38
Nov 17, 2008 09:22 PM
Sliver Doug
2004 - 2008 F150
Jul 31, 2005 11:46 AM
