C4 shifting too fast
Old Mar 20, 2005 | 10:14 PM
imlowr2's Avatar
imlowr2
I have a C4 transmission in my truck. When I cruise in it, the transmission shifts into second gear really quick. Is there anyway of delaying the shift from first to second, like the modulator valve? or maybe a problem with the vacuum? It's really annoying.
Old Mar 20, 2005 | 10:29 PM
Randy Jack's Avatar
Randy Jack
Ed -
I had the same complaint about my FMX. My tranny guy showed me where and how to adjust the shift point at the modulator valve. When that didn't work, I traced the problem to a leak (break) in the vacuum line from the manifold to the modulator. Sounds like a vacuum may be your problem, if it ever shifted right.
What he showed me was to pull the vacuum line off the modulator and turn the screw (deep) inside with a small flat blade screwdriver. (Push the vacuum line back on). Once my vacuum was restored, I dialed it in perfectly using the time honored trial and error method. Screw it in = shifts later, out = shifts earlier (I think). I am assuning that a C4 works/looks the same as my FMX.
Big help, huh?
Old Mar 21, 2005 | 06:11 AM
barry's Avatar
barry
Usually if a vac line is leaking or cracked, they don't shift. Check it anyway as they dry out over time. Make sure it is ok at the modulator end. THat's where they go bad the most. That elbow at the end.
Barry
50 F-1
Old Mar 21, 2005 | 12:13 PM
imlowr2's Avatar
imlowr2
Thanks guys. I think I might just replace the whole the vacuum line anyways, just to make sure. So Randy, how many times did you have to jack the truck up, turn the screw, test drive, come back jack the truck up, adjust, you get the picture, till it was right? LOL I was wondering if I can just screw it in a little and leave it? Would that work? I hate crawling under the truck if I don't have to. I'm not as slim and trim as I use to be. LOL
Old Mar 21, 2005 | 12:19 PM
Randy Jack's Avatar
Randy Jack
Ed - I'm not particularly slim either. I had to go under my (low) truck probably 6-8 times. I'm a slow learner. However, I didn't have to jack it up to get inder it. My Kamikaze driveway comes down a steep hill to the garage. Right in front of the garage, the driveway goes back up as an apron to the garage. I park the truck with the front wheels on the drive and the back on the garage apron and scootch under the running board to adjust it. It's the only time I am glad I have that cockamaymie driveway. LOL.
Old Mar 21, 2005 | 01:30 PM
fatfenders56's Avatar
fatfenders56
you didn't mention if this was a rebuild or not, but make sure the modulator you have has a white stripe there are others that fit but the range of adjustment is different. Randy is dead on about the high tech fine tuning procedure but I think the baseline is bottom it out and return 1 full turn
Ronnie Hundley
Mar 5, 2020 06:05 PM
Scope04
15
Dec 3, 2016 09:42 PM
tonfro
1983 - 2012 Ranger & B-Series
Jun 9, 2016 03:39 PM
shultzaberger
17
Mar 30, 2016 07:47 AM
idihillbilly
Jul 4, 2015 06:00 PM
