Don't Know What Else To Do
Old Mar 23, 2005 | 06:14 PM
  #31
retrogod1's Avatar
retrogod1
I have good vacuum every where but i do have a leak. I put my hand over the choke and it reved high
Old Mar 23, 2005 | 07:10 PM
  #32
retrogod1's Avatar
retrogod1
my girlfriends father thinks it might be under the carb. so i'll take it off i guess and check the gasket and make sure it sits right on the intake.
Old Mar 23, 2005 | 07:33 PM
  #33
ranger240's Avatar
ranger240
may be the intake gasket set if the carb gasket thing doesn't take care of it.
Old Mar 23, 2005 | 08:26 PM
  #34
retrogod1's Avatar
retrogod1
maybe, one thing at a time. I just took off the street advenger and set my old carb in there, but its only temp. cause i'm sure it needs to be rebuilt. But that wont get done till friday cause i'm broke till then.
Old Mar 24, 2005 | 02:50 AM
  #35
ACESN8S's Avatar
ACESN8S
I know it seems like a pain, but everytime I pull the carb after I've ran the motor, I replace the gasket. It's cheap insurance.
Patrick
Old Aug 25, 2005 | 12:06 PM
  #36
1968F100ShortBed's Avatar
1968F100ShortBed
Retro,
Did you ever solve your vacuum problem? I'm having a similar problem right now...pretty sure I have a vacuum leak, but can't find the source.
Thanks.
Old Aug 25, 2005 | 12:57 PM
  #37
72 f250cs's Avatar
72 f250cs
i know you replaced the fuel pump and carb but if it dying under load still sounds like a fuel problem either the carb isnt adjusted properly or you have a bad new fuel pump if you have access to a fuel pressure gauge i would test the pressure . what type carb did you get
Old Aug 25, 2005 | 05:20 PM
  #38
Almost_A_Merc's Avatar
Almost_A_Merc
I don't think it's the converter
Originally Posted by redhawkssh44
It sounds like your tourque converter is staying locked, you should have it tested. I had a simular problem on an 85 Olds Calais. It was a vacumn actuated overdrive problem. It wouldn't let the tourque converter unlock so when I put it into gear it would die.
This vintage of Ford didn't use a locking torque converter...
David
Old Aug 26, 2005 | 09:22 AM
  #39
ranger240's Avatar
ranger240
David
exactly, but what if it IS locking? old parts gather years of debris and gunk that jam stuff up when it isn't supposed to. I also don't know much about torque converters, or tranny's, so take my post for what it's worth.
89_IDI
Jan 9, 2013 01:12 AM
acreature
Nov 26, 2012 06:07 AM
BossFan
19
Aug 20, 2011 06:59 PM
djhecker15
Aug 5, 2011 08:39 PM
NH-Hottie
48
Nov 28, 2007 01:37 AM
