LS or locker
Old Mar 20, 2005 | 05:12 AM
Ford_Six's Avatar
Ford_Six
LS or locker
I have a 72 F-100 4x4, 9" rear. The axle code says it's open, but it has some sort of traction aid in it for sure. I need to change the oil in the rear end, but I don't know if it's a locker or LS. Is there a way to tell without pulling the center chuck? It always spins both tires with a little delay, if there is any noise, I can't hear it over the exhaust, but with one side jacked up doing the brakes I couldn't turn that wheel, just a little play rotationwise. Anybody have any insight for this?
Old Mar 20, 2005 | 07:45 AM
holland501's Avatar
holland501
Most brand name lube's will tell you on the bottle if they contain the L/S additive or not. Buy the one with the additive and you are good to go as it will have no effect on an open diff. Good luck.
Old Mar 26, 2005 | 11:25 PM
Ford_Six's Avatar
Ford_Six
If I jack up one side, and rock that wheel back and forth a few times, it will pop loose and spin with a little drag. Is this typical of a lunchbox locker? I know it has a traction aid of some sort, any time I make a sharp turn in a parking lot, it spins the inside tire a little, and the truck always wants to go sideways in the rain.
Old Mar 27, 2005 | 06:37 PM
TRaGiK's Avatar
TRaGiK
Sounds like a locker to me. If it's a locker, it doesn't matter what kind of fluid (with or without the additive), as long as there's fluid in it.
