Ford vs The Competition Technical discussion and comparison ONLY. Trolls will not be tolerated.
GM heading for Chapter 11?
Old Apr 4, 2005 | 07:34 PM
  #196
150ford's Avatar
150ford
Nope its not fixed. The engines still have it. Piston slap .com check it out. Yah he does sound crazy. They have powerstrokes that crank out more then that. Nothing new here.
Old Apr 4, 2005 | 07:53 PM
  #197
polarbear's Avatar
polarbear
Oh good grief- for the 100th time...fire up a 4.8, 5.3, (or 5.4 Ford- owned one) with aluminum pistons and you'll hear some "piston slap" for the first minute or two. Non-issue.
Old Apr 4, 2005 | 08:04 PM
  #198
150ford's Avatar
150ford
Sorry polarbear didnt mean to upset you there. But Ive heard some engines and some off them are pretty noisy. Its been a serious issue for GM. A whole website devoted to it.
Old Apr 4, 2005 | 08:09 PM
  #199
Nobetterorworse's Avatar
Nobetterorworse
www.leakingfords.com here's one for you, enjoy.
here's another <TABLE cellSpacing=2 cellPadding=2 width="90%" border=0><TBODY><TR><TD align=middle></TD><TD>http://fordsuckz.0catch.com/
and.... http://www.*********.com/
bon appetit.. http://www.ripoffreport.com/reports/ripoff110816.htm
http://www.forums.corner-carvers.com...ad.php?t=20965
http://www.f150online.com/forums/sh...threadid=167193
http://www.f150online.com/forums/sh...ght=piston+slap
www.timesert.com/<WBR>FORD TRITON SPARK PLUG REPAIR.htm
all for your reading enjoyment, glad to help.
</TD></TR></TBODY></TABLE>
Old Apr 4, 2005 | 08:29 PM
  #200
tmyers's Avatar
tmyers
Any engine, be it Ford, Chevy or Dodge that run forge pistons willl have piston slap. Get over it.
Old Apr 4, 2005 | 08:48 PM
  #201
duramaximizer's Avatar
duramaximizer
man thanks to nobetterorworse i got lots of reading material.
Old Apr 4, 2005 | 10:15 PM
  #202
polarbear's Avatar
polarbear
150ford Sorry polarbear didnt mean to upset you there. But Ive heard some engines and some off them are pretty noisy. Its been a serious issue for GM. A whole website devoted to it.
I'm not upset over it- but, website or not, it's a non issue. It's also a common characteristic of many makes.
Old Apr 4, 2005 | 10:48 PM
  #203
150ford's Avatar
150ford
I rest my case. Just check that website outin my second to last post and come to your own conclusions. Its pretty enlightning.
Old Apr 4, 2005 | 11:09 PM
  #204
polarbear's Avatar
polarbear
Ain't nothin' to rest- non issue.
edit: I knocked out that last remark- but I've made this statement before, and I'll make it again. Right now, in full-size pickups, GM's holding up the quality bar. Been documented over and over, variety of surveys. Want to refute that- please do- just document it.
Old Apr 4, 2005 | 11:14 PM
  #205
duramaximizer
it is so bad that gm has the highest resale value of the big 3.
Old Apr 4, 2005 | 11:33 PM
  #206
tmyers's Avatar
tmyers
As much has I hate to say this I will have to side with F150 on the Piston Slap issue.
If as stated they are using Hypereutectic Pistons they is no reason at all for any piston slap of any type. This piston should have tighter clearances than normal cast piston do to less expansion because of the high silicone content.
If on the other hand they are running Forged Pistons, piston slap is always present. This holds true for any manufacturer. Why do you think Diesels are so noisy when cold. Forged piston are used in almost every diesel application.
Forged piston are harder and take more abuse than any other type of piston but the trade off is thermal expansion requiring larger clearances. This is really only a problem when the engine is cold. All three type pistons will have the same clearances warm if the engine is assembled correctly.
Old Apr 4, 2005 | 11:48 PM
  #207
polarbear's Avatar
polarbear
I understand what you're saying- I'm just saying that from a durability/reliability standpoint it's a non-issue. From a customer standpoint, it's a non-issue. And our '03 Expy did it, so it's certainly not unique to GM.
Old Apr 5, 2005 | 12:12 AM
  #208
73Fastbackv10's Avatar
73Fastbackv10
Only for the model years 99-01. Read the asterisk in their truck adds for that bit of info.
Old Apr 5, 2005 | 12:30 AM
  #209
polarbear's Avatar
polarbear
I'd break that down even further- a 1500 Chevy will bring more than a Ford F150 (up to the '04 bodystyle change), but a F250 will bring more than a Chevy...especially if it's a PSD.
Old Apr 5, 2005 | 02:10 AM
  #210
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Sorry to take it off topic, but
If a F250 equipped with a PSD brings more $$$ than a similar condition and equipped 2500 Chevy, then the public obviously doesn't give 2 hoots about the so called unreliability of the 6.0l.
The superior stock performance obviously means a fair bit more to them.
correct???
