how much can I tow
Old Mar 19, 2005 | 09:43 PM
i82luz's Avatar
i82luz
Question how much can I tow
hello I own a 97 psd I hall a12,000# camper. I have recently added 4,500# YJ to the mix.I do have the super chip instaled. It pulled the camper alone fine.Does anyone thanke I might be pushing it thanks.
Old Mar 19, 2005 | 11:05 PM
Bluesbandit's Avatar
Bluesbandit
If memory serves Ford's manual say's both the 3/4 and full ton 97 PSD (standard or automatic), with a 4.10, is factory rated for towing maximum of 14k. Chipped might make it easier and more fun, but I'd be careful and keep an eye on the guages esp. tranny temp. Someone correct me if I'm wrong here, going from memory.
Old Mar 19, 2005 | 11:35 PM
MRBASS's Avatar
MRBASS
Legally sounds like you'll be over your GVWR, However the truck will handle it with no problem i'm sure. Is that a slide in camper you have that weighs 12000lb? or you pulling a Travel trailer\camper that weighs 12000lb and the 4500lb YJ too? Sounds like either way you'll have a gross weight somewhere around 23000lb?
Old Mar 19, 2005 | 11:43 PM
96 joe's Avatar
96 joe
i have a 96 that i use to tow about 16000 pounds with twice a week the truck and trailer combo on the scales is about 22700 with less than half a tank in the front the truck handles it fine but it doesnt like to stop it without alot of effort from the trailer also it likes to sway above 55 mph
Old Mar 20, 2005 | 08:36 AM
i82luz's Avatar
i82luz
thanks for your info.Has any one added a intercooler to 97 psd and if so was it a big healp.thanks again
Old Mar 20, 2005 | 09:03 AM
bigadam's Avatar
bigadam
i helped my buddy do an intercooler. It does make a differnce and its not that hard but i dont think its really worth the money to put it on.
Old Mar 20, 2005 | 10:41 AM
Kwikkordead's Avatar
Kwikkordead
Your biggest issue is going to be stopping and going down long grades. I can tell you from personal experience that you'll warp your front rotors on the first large hill that you have to slow down on. It was a '95 F-250 pulling a just a little more than the truck was rated for. And that was with brand new brakes. They were smoking by the time I got pulled over. Now that I have an F-550, no problems at all. Very large 4 piston calipers on each wheel.
Old Mar 20, 2005 | 01:42 PM
barebackjake's Avatar
barebackjake
does the camper wieght 12k or is that the grwr # on it?
that would be one massive camper to wiegh that much.
my 4 horse trailer with living quarters thats 44' long is 9k empty and dry
best bet is to take it to the scales and get it wieghed
