1985 Ford f-150 had a 6cylinder, converted to a 351 windsor with automatic, ran fine until I decided to clean out some dirt from the distributor. Removed it sprayed it out, let it dry two hours, replaced it, truck wont start. Replaced TFI module, replaced coil, went to salvage yard got 2nd dist, NO help, engine turns, no spark, traced all wires, power on three of the six on the plug on the side of the dist.with key on, dont know what else to do Can anybody help Please
okay I have asked several times, whats a DIZZY?????????????, I replaced all the interior and exterior components and the coil with a new Dist Body and cap
jimmy1950, I can't tell you how many times I have overlooked the obvious because "I" just knew that couldn't be the problem and wasted untold hundreds of $ only to find out that "I" was wrong. If you have spark and fuel then next is timing. Good luck.
