Bronco II Ford Bronco II
How much trouble is it to replace TFI module?
Old Mar 3, 2005 | 09:10 PM
threespeed's Avatar
threespeed
The book says to remove the dist. to service the TFI module. Is there any way to remove it with the dist. still in place? The screws that hold it on the dist. are real close to the fire wall. Can they be removed while the dist. is still in the motor?
Old Mar 4, 2005 | 12:16 AM
Monty06's Avatar
Monty06
yes you can remove the tfi module without removing the distributor. you need a ford ignition module tool to remove torx screws you have two of them just go into any autoparts store and look for a ford module tool cost is like 5bucks,
Old Mar 4, 2005 | 11:23 PM
Chris89lx's Avatar
Chris89lx
I ground a socket down to fit the TFI module but it would be way easier to just buy the ool.
pete17c
Jan 31, 2010 09:08 AM
pdd
17
Feb 21, 2008 09:56 PM
iceman7329
Jul 15, 2007 07:33 AM
jimmy1950
Jun 1, 2005 04:25 PM
jbrote47
Bronco II
Jan 12, 2001 10:26 PM
