help with programmers plz
Old Mar 18, 2005 | 01:01 PM
Choctaw Bob's Avatar
Choctaw Bob
Originally Posted by bricot
Are the 6.0L's intercooled?
Yep...............
Old Mar 18, 2005 | 01:11 PM
bricot's Avatar
bricot
Originally Posted by jdadamsjr
Understand Bricot.... not trying to escalate a war either...
just as I did when I investigated whether or not I wanted to go to the SCMT when it came out... even though I had already had fun with the predator for months...
I just like to make sure I got my facts straight....
and so I just asked for clarification of what tranny problems
cuz I ain't got no stinkin' tranny problems
Have a good weekend...
Cool, just wanted to make sure I hadn't made you mad, I was trying to regurgitate what I had heard certainly not from experience, but after the recent points made and after talking to SOMEBODY at motorhaven... I think I'll actually go with the Predator.
Going to go pick up the truck in an hour .... y
Old Mar 18, 2005 | 01:40 PM
jdadamsjr's Avatar
jdadamsjr
Good luck....
Hey, that's what research is about....
and fyi...
very few things on here makes me mad.... some of the troll statements warm me up sometimes... but hey - it's winter - that's a good thing :-)
and I LIKE this place so I wanna keep it helpful to ME as well as others !!!
Old Mar 18, 2005 | 01:59 PM
FTE Ken's Avatar
FTE Ken
The fact of the matter is I don't think any programmer will disappoint a customer. They all have their positives and negatives. Competition is good for the products.
Old Mar 18, 2005 | 02:32 PM
Vic_Ferrari's Avatar
Vic_Ferrari
Originally Posted by PSD 60L Fx4
SCT and SCMT use RPM-anticipated shifting. .
Not just RPM, but also MPH. MPH is the primary decision for shifting at part throttle.
Old Mar 18, 2005 | 02:34 PM
Vic_Ferrari
Originally Posted by Choctaw Bob
Any time you install new batteries, put a new program in the PCM with the Predator or the SCMT or disconnect the batteries for any other reason, you must take the truck through the tranny learn proceedure. .
Unless, the logic is changed within the program.
Ahhh, that's part of the ticket =o)
Old Mar 18, 2005 | 02:38 PM
Vic_Ferrari
Any time you install new batteries, put a new program in the PCM with the Predator or the SCMT or disconnect the batteries for any other reason, you must take the truck through the tranny learn proceedure. This is in your owners manual. There is no "100" mile learn time. Someone just picked that number. You can easily see if you installed a tune, got on the freeway and drove 100 miles you would not acomplish a learn cycle in 100 miles. The learn cycle that is recommended is in the technical articles at the beginning of this forum.
For anyone to say that the SCMT or Predator trans program is "better" than the other is pure speculation. No one making those statements has ever done a comprehensive test with installed pressure gages and other data acquiring devices. The only people who have done these tests are possibly the manufacturers who will not divulge the results.
We have made note of the fact that in our (unscientific) dyno tests on different trucks that the SCMT makes about 50 HP less than they claim and the Predator makes about 50 HP more than they claim. If SC will make misrepresentations in their advertising about their power levels, it follows that they are likely to be liars about their transmission tuning as well.
Above all, one should not believe anything that a certain SC representative posts on these forums. These statements in the past have proven to be less than factual.
Bob.
I do believe you are stepping out of line.
Moderators?
This post is outright unacceptable and unprofessional.
The plots are available.
Check those 1/4 mile times.
If I'm not mistaken, you still have never driven a truck with the tuner you so openly bash, nor have you seen the kind of "loaded" power it makes.
I am VERY careful what I say when I post and so should you.
I must say, I am disappointed.
Why don't you come down, and I'll SHOW you some of the parameters changed and take you for a ride?
Would you like to see the equipment I've used and the 1/4 million dollar dyno with test profiles used to test?
I can constantly monitor EGT, boost, line pressure, injectore timing, ANY engine or trans parameter.
Lets be nice here!
Old Mar 18, 2005 | 02:39 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
Bob, I think you know that I think of you quite highly, but I am not sure that comment was neccessary.
From everything I have seen personally (and yes, I have acculmuated quite a bit of custom tuning equipment for these trucks, and have taken a close look at the interal coding of many of the products on the market) noone here from SC has been lying about anything. I can send screenshots of information proving the difference between the transmission profiles of the Predator and SCMT, and IMO the methods used by SC are far superior to that of DiabloSport.
As for data aquisition, yes, many tests have been run. Many SCT dealers (including the one that did my intial base files) cylinder pressure test each tune on a truck with an identical processor before the file is ever sent out to the customer. As far as I am concerned, and this is just my opinion- it can be taken for what it is worth- the Predator DOES use too much injector timing, DOES ramp the timing too early in the powerband, DOES run too hot for the amount of power that it makes, DOES have some very questionable cylinder pressure spikes, and DOES NOT shift as well as competing products.
Every drop of information I stated in my earlier post came from testing that either I have done personally, on my vehicle, or data that has been derived from personal friends of mine at SCT (NOT affilated with Superchips, Inc.)
If anyone wishes not to believe me, I will certainly not flame them. Everyone is entitled to thier own experience and beliefs.
Old Mar 18, 2005 | 02:40 PM
SpartanDieselTech
Former Vendor
I mentioned these changes earlier, but I'm not sure anyone really noticed...
Old Mar 18, 2005 | 02:45 PM
Vic_Ferrari
Lets start this thread fresh with a friendlier tone.
Bob, no disrespect on my part, you have simply not been fully informed on how the programming works, and I can assure you that I have tested it painstakingly, logging all data.
I can only be so specific (especially in an open forum) because I can't just say "Go to address 540A and change this byte to this and this byte to this and remap this table here".
I just can't share that type of information.
FTE Ken's Avatar
FTE Ken
Sometimes FTE feels like hearding cats....
Old Mar 18, 2005 | 02:46 PM
Vic_Ferrari
Indeed it is =o)
Lets just keep it friendly!
Old Mar 18, 2005 | 02:52 PM
  #28
Vic_Ferrari
Every drop of information I stated in my earlier post came from testing that either I have done personally, on my vehicle, or data that has been derived from personal friends of mine at SCT (NOT affilated .
Chris from SCT and I had spent a lot of time (a while back) working on the 6.0 and exchanging information (which is part of why there are similarities with the SCT and SCMT).
There are some differences in each companies products, basically just due to different taste, but the logic behind it is the same.
Old Mar 18, 2005 | 02:53 PM
  #29
FTE Ken's Avatar
FTE Ken
Too many supposed experts out there.... everyone thumps their chest about certain products, because they have a financial interest or because its the product they bought.
I hear people talk up the SCMT:
Well... its got a great shift but many customers prefer the way the Predator builds up power. Suffers from poor diagnostics and no web updates.
I hear people talk up the Predator:
Great power all the way around but there is a slight learning curve with the tranny and some people don't prefer its shift for extreme towing. Web updates and great diagnostics.
I hear people talk up the SCT:
Great power, tons of it, but it has horrible throttle feel for many customers, though they are supposed to be addressing that soon. No diagnostics, but your tuner can email you tunes. Great for wide open driving, not as much fun for lots of part throttle stop and go.
EGTs:
All of them run safe EGTs, especially considering that indications, IMO, are the 6.0 handles EGT better.
So before everyone gets into a peeing contest, be careful because I deal with all three products and I can pour some pee on everyone of them, as well as heap praise on them all. They are all great products, each with some market overlap, plus each with their own niche.
Old Mar 18, 2005 | 02:56 PM
  #30
Vic_Ferrari
I think this is a big key here.
Some like a higher spike, some like a longer powerband, some like and inline device.
Try them all!
