Solder for wires..
Old Mar 17, 2005 | 08:52 AM
YOMAN's Avatar
YOMAN
Solder for wires..
I m looking for to buy some kind good quailty solder for my truck electric wires, hobby RC car etc..
I guess it doesnt matter what brand of solder is it ??
I want something good qauilty solder that would not break off easy.
Any brand do you recommended??
Thanks!
YOMAN!
Old Mar 17, 2005 | 10:12 AM
DonsFx4's Avatar
DonsFx4
Ford sez..."DO NOT USE acid core solder, use a rosin core mildly activated solder". The smaller the gauge, the easier to work with.
I prefer using solder paste instead of solder with flux in it.
Any brand will do as long as it meets the above specs.
Old Mar 17, 2005 | 11:00 AM
YOMAN's Avatar
YOMAN
Umm paste, is it good is it like a glue?? where can i find one ? home Depot?
thanks!
YOMAN!
Old Mar 17, 2005 | 11:35 AM
Mil1ion's Avatar
Mil1ion
You won't get the wrong if you buy it at Radio Shack.
It comes in a little plastic vial like crazy glue.
Old Mar 17, 2005 | 11:36 AM
Jamie Miles's Avatar
Jamie Miles
Go to Radio Shack and tell them you want some Radio/TV solder.
Old Mar 17, 2005 | 12:05 PM
Torque1st's Avatar
Torque1st
Posting Legend
Kester brand solder available at electronics supply stores. Some of the stuff at RS has been substandard over the years so I do not trust it.
Old Mar 17, 2005 | 12:06 PM
dono's Avatar
dono
Gone but not forgotten.
Back in the day when I was installing process control computers I soldered thousands of wires. I like the Kester thin wire (.031), resin core, 60/40 alloy. Good luck.
Dono
Old Mar 17, 2005 | 01:35 PM
76supercab2's Avatar
76supercab2
If your solder joint breaks or is brittle then you did something wrong. Probably a cold joint or you heated just the solder and not the wires. Many times this problem can be caused by using solder that is too thick for the job. Get the thin stuff. It will probably be about the same diameter as your wire. Then when soldering, put the iron on the wire joint and heat the wire, touch the solder to the wire and allow the heat in the wires to melt the solder. Allow the solder to flow into the joint. Remove the solder and the heat and don't move the joint or wires till the solder cools. Practice with some scrap wires a few times and you'll get the feel for how fast you can go. The trick is to get enough heat in the wire to melt the solder but not to melt the insulation next to the joint.
Old Mar 17, 2005 | 01:47 PM
CheapRanger's Avatar
CheapRanger
Where is a good place to buy silver solder?
Old Mar 17, 2005 | 06:30 PM
nightowl_52's Avatar
nightowl_52
I've been using Radio Shack's 60/40 Rosin core for many years now. I also never solder anything without using soldering paste flux. My choice is alpha metals brand. It gives you a nice solder flow cause it cleans the surfaces for a good bond.
FordTruckGuySTX
Oct 8, 2006 10:04 AM
Longneck
13
Nov 20, 2005 07:14 AM
YOMAN
Jan 8, 2005 01:03 PM
Longneck
Jan 21, 2004 05:25 PM
whistler
Sep 17, 2003 05:05 PM
