paint for master cylinder
Old Mar 17, 2005 | 06:01 AM
g84t8f1's Avatar
g84t8f1
what paint would work good on a master cylinder? mine will be under the truck like stock.I have a new booster and master cylinder and would like to protect them the best I can.has anyone done this ? THANKS ART
Old Mar 17, 2005 | 06:18 AM
ALBUQ F-1's Avatar
ALBUQ F-1
I'm not positive, but I believe G.E. Glyptal is resistant to brake fluid. Not much choice on color.
Old Mar 17, 2005 | 08:44 AM
fatfenders56's Avatar
fatfenders56
I use Glyptal inside engine blocks and it holds up, I would think it would hold up on a M/C.
Old Mar 17, 2005 | 01:42 PM
Spitfire44's Avatar
Spitfire44
I've seen them powder coated. They can put plugs in the holes so the threads and insides don't get the powder coating on them.
Old Mar 17, 2005 | 05:13 PM
Madathlon's Avatar
Madathlon
Spitfire44 is right, The only thing you can really do is powder coat them.. Brake Fuild is the best paint remover out there I have seen LOL ..
Old Mar 17, 2005 | 05:55 PM
rogerf100's Avatar
rogerf100
Eastwood catalog has a few options for painting the master cylinder. Spray Gray for cast iron parts, Brake Drum/ Caliper Coatings in gray or glossy colors good up to 900 degrees F.
Old Mar 17, 2005 | 08:28 PM
g84t8f1's Avatar
g84t8f1
thanks for the info.what is the cost of powder coating?I would like to powder coat alot of stuff if it's not to high.can you do it yourself?I've done bodywork and can paint a auto.If it's to much I'll try Glyptal. THANKS ART
Old Mar 17, 2005 | 08:32 PM
Madathlon's Avatar
Madathlon
There are some do it yourself kits out there but U need a oven that you will never use for anything else but powder coating... And they do wrk great.. I have used then myself and love doing all the small stuff..
Old Mar 17, 2005 | 08:39 PM
g84t8f1's Avatar
g84t8f1
WHERE did you get your kits?I can find a old oven. whats a kit cost? THANKS ART.
Old Mar 17, 2005 | 08:43 PM
Madathlon's Avatar
Madathlon
I get mine from eastwood.. here the link
http://www.eastwoodco.com/shopping/s...&keyword=HCKIT
Old Mar 17, 2005 | 09:03 PM
g84t8f1's Avatar
g84t8f1
LOOKS like I'LL be powder coating. THANKS
Old Mar 17, 2005 | 09:20 PM
Last Chance 55's Avatar
Last Chance 55
I actually used a aerosol bed liner spray that I purchase from Wal-Mart. If any has ever bled manual brakes, I covered the master cylinder in brake fluid about 15 times. It is still holding up.
Old Mar 17, 2005 | 09:23 PM
g84t8f1's Avatar
g84t8f1
Never thought of bed liner.might work good for undercoating. THANKS
Old Mar 18, 2005 | 01:02 AM
51ford fan's Avatar
51ford fan
I have always just sprayed them periodically with any spray bomb I have on the shelf with a matching color. It doesn't last that long anyhow.
Rod
Old Mar 18, 2005 | 01:50 PM
AXracer's Avatar
AXracer
Harbor Freight has the best price on powdercoating kit, < 50.00. Oven needs to be electric, not gas and capable of reaching and holding @ 400*F.
If you plan to powdercoat the MC you will need to disassemble it completely, the rubber seals will not take the heat, and plug or cover any/all machined surfaces. You will NOT be able to powdercoat the booster tho since you can't take it apart to remove the diaphram(s). I'm using a polished stainless booster and aluminum MC so I don't have to worry.
