Bronco II Ford Bronco II
fuel pressure regulator
Old Mar 16, 2005 | 07:22 PM
jakemahn's Avatar
jakemahn
Hi all, this is my first time posting, I have certainly benefited from viewing others comments to solve my B-2 problems. I just replaced the fuel pressure regulator on my 88 B-2, 2.9L. I thought that might be the cause of my broncos loss of power up hill and just in general. Now the thing won't stop leaking around the o-ring. I have tightened the bolts as much as possible. Some history; I have replaced the fuel pumps(in tank and in line), the fuel filter and many other parts. Any suggestions.
Old Mar 16, 2005 | 07:57 PM
BAYDOG's Avatar
BAYDOG
Pull the regulator off again, and carefully take some fine steel wool and clean the fuel rail where it goes in, then use some grease on the o-ring when you put it in. Make sure it is seated all the way in the hole and seats even when you tighten it in.
Old Mar 17, 2005 | 08:02 PM
Ken00's Avatar
Ken00
Also inspect the O-ring for any damage.
Old Mar 21, 2005 | 12:54 AM
jakemahn's Avatar
jakemahn
Thank you for your help. I used steel wool around the hole in the fuel rail. Also the new o-ring was torn, so I put downward pressure on the regulator while tightening the bolts to ensure the regulator seated straught into the rail. I may have screwed one side too much hencce tearing the o-ring. All is well, I am conserving gas again.
Old Mar 21, 2005 | 08:02 PM
Ken00's Avatar
Ken00
Glad to hear your not leaking anymore!!!
crmiv67
Aug 9, 2013 04:06 PM
countrycar
Nov 21, 2012 07:16 PM
chrismanjoa
Feb 18, 2012 05:05 PM
Cow-Tipper
Bronco II
29
May 9, 2006 07:49 AM
